KD4UPL - Thanks. I forgot about passengers...because I won't have any. Its just me. Ford says the capacity assumes a 150lbs driver. I'm about 50lbs over that. I already have tools, heavier tires than the gas sipping OEM tires so I'll probably add 200lbs. A lawyer friend of mine said even if accident is not your fault, lawyers will argue that anything over 90% is unsafe and they usually win.
Boomerweps - Thanks. Cargo trailers are out for me. I've built many things from scratch before. However, I'm too honest to be a good salesman and never make any money. Too easy to turn into a money pit.
canoe on top - I didn't research wind resistance, so thank you. I looked into it and I should be OK. My SUV's height is 68". Typical small camper height is only 90 inches, so only 22" is sticking up. Width is less than a typical camper too. Most of these small campers are slanted on the front, so I should be OK, correct?
Trailmanor and Unobtainium weigh too much but thank you for your posts.
I'd like to find a good deal on a used Prolite Mini/Cool/12V. Most Prolites don't have A/C so guessing another 100lbs on a mini split (not AC unit), but any under 1200lbs should be OK, correct?
Thanks
I was surprised picture from Prolite website - 1390lb towed by mini. Technically it's within Mini's tow capacity, but yeah say goodbye to that Aisin tranny.
