Dec-03-2014 12:50 PM
Dec-08-2014 06:58 PM
Dtaylor wrote:
One of the times I had a propane tank filled, the guy used the screw on side of valve and vented tank, basically overfilling it. That tank would not work on my camper until some of the propane was used out of the tank. (I use a larger tank to refill my 1lb. bottles)I do not know if the older regulators are like that.
Dec-08-2014 04:26 PM
drsolo wrote:wrenchbender wrote:
Had one of those TT for 14 yrs.A word of wisdom, after you get the propane problem solved reseal the clearance lights.
??? what are the clearance lights?
Dec-08-2014 03:29 PM
Dec-08-2014 02:09 PM
Dec-08-2014 01:39 PM
Dec-08-2014 01:23 PM
Dec-08-2014 07:59 AM
Dec-07-2014 09:14 AM
Dec-03-2014 07:28 PM
drsolo wrote:Old-Biscuit wrote:
Light off all 3 stove top burners on high to get propane flow and place regulator in service (establish a demand)
...couldnt do that, could barely get one turned on and lit. Flame was blue and very low. When we turned on a second burner the first one started pulsing and went out.
Stove top burners will give you a good indication of propane flow and regulator.
... so what does it mean? The propane tank is full (it weighs 35.5 lbs)
In some of your pictures you have questions and or ???
The roof vent on left side---that is fridge exhaust vent (lower one on side allows air in that flows upward across backside of fridge and out top) Good air flow draft) needed for proper cooling of fridge
The ?? in side picture (door, stove vent & furnace exhaust vent)
The item in ?? is the door stop/latch. Push door fully open and it will press into round latch on bottom of door to hole it open.
... THANKS!!!
Propane system.....
I would replace regulator and pigtail hoses with new
... will do that.
Dec-03-2014 06:02 PM
... couldnt do that, could barely get one turned on and lit. Flame was blue and very low. When we turned on a second burner the first one started pulsing and went out.
... THANKS!!!
Propane system.....
... will do that.
Dec-03-2014 05:58 PM
Dec-03-2014 05:51 PM
Dec-03-2014 03:02 PM
Dec-03-2014 01:39 PM
