Help!!! Please. 1992 Pastime camper my markerlights "hub"
Dustin2Dags
I have attached a few pictures....I tore apart a wall, as I thought some one (to save money) just rewired the 5 pin with only three wires.
I have looked all over looking for where the main power is fed to all the marker lights and I cant find them.
The pictures are of the wall I tore out, behind the inverter (I can account for all the wires)But none for marker lights. Any one with knowledge of were I can tap in as they do not work. Any help would be great thanks!!
URL photos only? not sure if the photos will work..
27 REPLIES 27
Dustin2Dags
AnEv942 thanks!!!
Dustin2Dags
Victory402 you rock!!! thanks.
Dustin2Dags
http://i773.photobucket.com/albums/yy11/dustin2DAgs/bee808eb-c3cb-4488-a26e-b58e7da29cdd_zps5380885f.jpg
Victory402
AnEv942
PM sent
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Dustin2Dags
if any one could give me some feed back weather these are "usable links" or not. That would help at least be able to give some photo documentation of my issue.
Dustin2Dags
http://i773.photobucket.com/albums/yy11/dustin2DAgs/wall_zps38a6125c.jpg
Dustin2Dags
http://s773.photobucket.com/user/dustin2DAgs/media/d8b04357-a46c-466a-9450-64029239fed7_zpsda622645.jpg.html?sort=3&o=0
Dustin2Dags
The issue is the lights do not work, and i'm looking to find where I can supply power (and ground) to get the lights to work. I have photos of my campers plus every where "it looks like it should be" but its not there. I have removed a wall (just the finishing panel) but its destroyed by doing it. Looking for some help on places to look or if some one has the same camper and knows where it is please please please help. Its not with the inverter wiring. the only pig tail to come out of from left is 12+ power for lights (inside) not out side, the heater and that is it. It has a propane refrigerator, so no power for that. Any and all help, even if its just pointing me in the right direction.
Dustin2Dags
Can any one tell me how to post a picture? why it is so complicated?
Dustin2Dags
http://s773.photobucket.com/user/dustin2DAgs/media/d8b04357-a46c-466a-9450-64029239fed7_zpsda622645.jpg.html?state=copy
Dustin2Dags
[img]http://s773.photobucket.com/user/dustin2DAgs/media/inverter_zpsa9c40885.jpg.html?filters[user]=138262588&filters[recent]=1&sort=1&o=0[/img]
http://s773.photobucket.com/user/dustin2DAgs/media/wall_zps38a6125c.jpg.html?filters[user]=138262588&filters[recent]=1&sort=1&o=1
http://s773.photobucket.com/user/dustin2DAgs/media/camper_zps7447e275.jpg.html?filters[user]=138262588&filters[recent]=1&sort=1&o=2
testing to see if pictures post
AnEv942
Yes photos need to be hosted some where-photobucket etc.
Without seeing where your at-assuming you are inside where pigtail feeds camper. -If it has running lights-should be a wire someplace?
, oh do you have taillights?
If the taillights are also not working and the hot lead is not hooked to anything (you only have sigs & brake) you 'could' run a new wire to a taillight, usually more accsesable, Or if you can get to one running lights they are generally daisy chained. Need ground also-not sure what wires you have now. Lot of ifs..
