HELP
Wallace_9967
You aren't going to believe this but I'm locked inside my camper ! Apparently when my wife left to pickup our grandson , she locked the camper door but didn't return the key to it's proper position. I've removed the inside plate but no joy . Anyone have a suggestions ? I can get out the escape hatch .....but is there another way ?
30 REPLIES 30
kerry4951
Irecently took off my door latch and lock. The outer part of the lock is held into place by the striker plate on the latch side of the door, so you cant remove the lock from the inside, atleast not till you get the door open. The escape window would be the only other way out as far as I know.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
