Hensley Arrow - Need Answer
ken07734
Just finished installing the Hitch and I have a few questions.
1. it sits a bit lower than my old hitch, enough so that I am concerned it may drag or hit something....
2. answering this may answer question 1, how much tension can be on the bars? Can I tension them enough to raise the rig a few inches?
3. Since I have the 4 inch bar ( I believe) can I just flip it over and have it raise instead of lower?
Anyone with this hitch have any answers? I would greatly appreciate it!
17 REPLIES 17
ReneeG
dalenoel wrote:
Flipping the stinger may not be the correct procedure. Contact Hensley and see what stinger should be used with your trailer and truck. They do a great job swapping the stinger if needed on a purchase.
I agree. Before our fifth wheel and the Hensley BD3 TrailerSaver hitch we had a TT and the Hensley Arrow. Ours appeared to sit low too, but the hitch height is very important. We had to swap ours out twice to get the perfect fit and yes, they are very good about it. It's important to be level because backing that stinger into the hitch takes some finesse and getting used to.
Here's a picture of ours as it was on our Komfort TT 282TS -
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
dalenoel
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
goducks10
You can crank the spring bars all the way to the top and it won't hurt it. There's a video from HA that shows them cranked all the way up. And (insert name) says no problem doing it. With the HA you can't preload the WD the normal way so cranking on the spring bars is all you can do.
