May-31-2014 10:20 AM
Jul-08-2014 09:11 AM
Jul-08-2014 08:19 AM
Jul-08-2014 02:35 AM
Jul-07-2014 10:30 PM
Highway 4x4 wrote:
I bought my Honda E3000is back in 02. Just change oil and air filter. 1 new battery for the electric start. No issues, always runs. I think I paid about 1800 for it back then. I have not found a better gen yet.
Jul-07-2014 10:19 PM
Jul-05-2014 02:10 PM
Jun-02-2014 02:54 PM
Jun-02-2014 02:35 PM
dieselenthusiast wrote:There is nothing magical about a generator motor. It has pistons, rings and a crankshaft like most other engines including cars.
I was able to read several reviews from those who own the Yamaha EF3000iSEB with the tri-fuel kit from US Carburetion. I also watched a few videos and read further reviews from others who have installed similar kits from Central Main Diesel. In short, these generators work as advertised using natural gas and propane. In these kits, the propane consumes about the same amount of fuel (gallon to gallon) as gasoline. Also, there is no lose in power as proven by real world data. And no, you can't compare these generators to gasoline car engines.
Based on my research, I felt very comfortable ordering the Yamaha EF3000iSEB tri-fuel kit from US Carburetion (a Yamaha dealer). It came with FREE shipping and Yamaha threw in an additional 1 year warranty for FREE (for a total of 4 years). I will run gasoline under moderate load for 3 hours (break-in period), then switch to propane for long-term use. After using the generator for a few months, I will post up a review and report my real-world data so others can make more informed decisions.
Jun-02-2014 01:18 PM
Jun-01-2014 10:24 AM
Huntindog wrote:Travels with Yoly wrote:
Also, being able to adjust RPM as described is pointless since all generators have to run at a set 3,600 RPM in order to produce 60 cycles per second. Anything above or below that won't produce a proper sine wave.
That is correct for standard type generators.
The two generators in question are both invertor types. They do not run at a fixed RPM. They idle up and down depending on the load. Not sure exactly how they do it, but the power is regulated electronically somehow.
Jun-01-2014 10:05 AM
Jun-01-2014 07:09 AM
Rally's attended so far-21
Jun-01-2014 05:44 AM
Jun-01-2014 02:18 AM
