โJun-07-2014 08:44 AM
โJun-13-2014 03:21 PM
โJun-07-2014 04:27 PM
myredracer wrote:
It's easy to run out of hot water when showering and nothing unusual. First thing to do is go and buy an Oxygenics shower head (around $40). They use less water make a HUGE difference. If you happen to have an electric element, you can run that in addition to propane and you will have faster recovery on the tank.
We have had an Oxygenics shower head on 3 TTs now and have not had a problem with running out of hot water and have not had to use water saving techniques.
โJun-07-2014 04:24 PM
โJun-07-2014 04:21 PM
โJun-07-2014 04:11 PM
โJun-07-2014 02:52 PM
old guy wrote:
one solution many of us have found is buying a oygenics shower head. they use less water and you can take longer hot showers. some years ago my daughter , who had super thick hair would run out of hot water before getting the shampoo out of her hair. bought the new shower head and she even said "thanks Dad".
โJun-07-2014 01:55 PM
โJun-07-2014 12:27 PM
โJun-07-2014 12:12 PM
โJun-07-2014 11:56 AM
2008FX4 wrote:Fishinghat wrote:
Since you've run out of hot water so quickly, it may be due to having the winterizing valves turned the wrong way. That causes the cold water to enter the top of the tank and almost immediately mix with or replace the hot water. So, check your valves.
Second, most experienced RV'ers take "Navy showers", where they turn on the water, get wet, turn off the water, soap up, then rinse off. This reduces the amount of water used considerably.
I think I have them right. There's no arrows saying off or on. So I have to guess.
And we take navy showers. I've been rving my whole life so I know that's just part of camping.
โJun-07-2014 11:10 AM
โJun-07-2014 10:39 AM
Caveman Charlie wrote:
Hum,,, I never have a problem. You say you have been RV'ing for a long time. Have you had this problem in the past with other water heater on other RV's? Or, is this a recent issue with a new to you RV?
โJun-07-2014 10:28 AM
2008FX4 wrote:It's not part of MY camping! ๐
โJun-07-2014 10:06 AM
