how can I find info on the capacity of each grey tank?
trailernovice
Our new trailer has two grey tanks...one for the shower/the other for the kitchen sink...has two grey outlets--the black outlet is linked into one of the grey outlets, and the other grey outlet is stand-alone...
here's the issue...I see the TOTAL grey capacity in the specs, but nothing about how this total is divided between the two tanks...ex. does it hold 10 on the 'galley' tank and 42 on the shower tank? vice versa? an even split between the two?
curious because I don't want a repeat of the 'water is backing up into the bathtub' thing
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
19 REPLIES 19
SteveAE
The manufacture of my trailer had the wrong size listed (it is smaller than they said). If you really want to know for sure, measure the tank size and calculate or pour water in it. Advantage of adding water is you can get a relative calibration of your monitor (add water and watch the monitor transition). Of course, this calibration will be subjective to how clean your sensors are, but it's better than nothing. Did the same for my fresh water tank too. Now I have a fairly accurate monitor for the fresh tank and a much better "guess" for the grey and black.
BTW, you can make a black water tank dipstick (old broom stick with calibration marks on it) that will always be accurate (as long as there is no pile)
trailernovice
got the answer....called the manufacturer (based on a reply in this thread)....now, why didn't I think of that?
Anyway, each gray is 26 gallons...makes sense...as one post-er suggested, generally multiple tanks will be of even size...the spec sheet on our current trailer shows:
Black Water 26
Gray / Galley Water 52
manufacturer rep told me they're all the same size...a 26-gallon black, and two 26-gallon greys...
our last trailer had a single grey tank with a 42-gallon capacity/black tank held 32 gallons...
Glenn and Toni
TucsonJim
fla-gypsy wrote:
I find it amusing that some of you think the maker actually knows what size tanks are on the product they make or would lug water in a TT to pour into the tanks with a bucket that may or may not actually be 5 gallons. If you can see the tanks some simple math will give you all you need to know within a gallon or two.
I find it amusing that you're concerned about the accuracy of a five gallon bucket, but are okay with an answer that's "within a gallon or two".
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
4X4Dodger
downtheroad wrote:
Give them a call:
Customer Service Hours
Monday - Thursday: 8:00 A.M. - 5:00 P.M.
Friday: 8:00 A.M. - 3:00 P.M.
Customer Service: 855-226-7496
Email: warranty@crossroadsrv.com
Have your VIN handy and they can answer virtually any question about your rig.
camperforlife
Trailernovice the specs say black 26 gal grey/galley 52 gal. I would think it is pretty safe to say all three tanks are 26 gal as most TT manufacturers drop the same size tank in all locations.
fla-gypsy
downtheroad
Tx wrote:
Well I was told at the dealer and in all the brochures that I had read on our trailer that the grey water was 23 gallons.
I was under the trailer doing some wire clean up and just checking things.
Then I noticed molded into the bottom of the plastic tank 32 Gallon!
Were you maybe laying on your back when you were under the trailer and looking at it up side down...23=32
:E
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
TxTwoSome
TucsonJim wrote:
I use the five gallon bucket method. Fill 'em up, drain 'em out one at a time. Even though they advertise a certain size tank, insertion of the drain and vent pipes can reduce that capacity. Actually measuring will give you the most reliable answer.
HMMMMM good info I had not thought about that..
Now where the heck is my 5 gallon bucket???:B
Bruce & Cindy (Chihuahua's Rambo & Chuy)
2016 Jayco 23RLSW
2014 Ram 1500 5.7 Hemi
Blue Ox SwayPro
TucsonJim
bdpreece
Depending on how the tank is mounted and how it is plumbed it may not hold the full 32 gallons. Then again maybe the person who wrote the specs was dyslexic. 32 - 23 my wife does it all the time.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
gmw_photos
Houston Remodeler wrote:
The size of every grey tank is pretty constant;
Just small enough to slosh grey water into the shower pan as you drive down the road.
Hmmm. That is an interesting comment. I've towed many hundreds of miles ( probably more like several thousand miles ) with varying amounts of water in my gray tank, and never had that happen.
Houston_Remodel
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
TxTwoSome
2016 Jayco 23RLSW
Blue Ox SwayPro
gmw_photos
bdpreece wrote:
....snip......
You can get pretty close by turning your hose on full and timing how long it takes to fill a 5 gallon bucket then with empty tanks time how long it takes to fill until the water starts to come up in the shower drain or the sink.
I vote for this method !! 🙂 It doesn't get much easier than this.;)
