how can I find info on the capacity of each grey tank?
trailernovice
Our new trailer has two grey tanks...one for the shower/the other for the kitchen sink...has two grey outlets--the black outlet is linked into one of the grey outlets, and the other grey outlet is stand-alone...
here's the issue...I see the TOTAL grey capacity in the specs, but nothing about how this total is divided between the two tanks...ex. does it hold 10 on the 'galley' tank and 42 on the shower tank? vice versa? an even split between the two?
curious because I don't want a repeat of the 'water is backing up into the bathtub' thing
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
19 REPLIES 19
lc0338
If you can measure the dimensions just plug them in HERE
downtheroad
Give them a call:
Customer Service Hours
Monday - Thursday: 8:00 A.M. - 5:00 P.M.
Friday: 8:00 A.M. - 3:00 P.M.
Customer Service: 855-226-7496
Email: warranty@crossroadsrv.com
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
bdpreece
I would probably contact the manufacture first but if that did not work;
You can get pretty close by turning your hose on full and timing how long it takes to fill a 5 gallon bucket then with empty tanks time how long it takes to fill until the water starts to come up in the shower drain or the sink.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
trailernovice
donn? that's too much of a common-sense approach for me to grasp....can't everything just be googled?
Glenn and Toni
donn0128
Fill them and using a 5 gallon bucket drain each one recording the number of buckets full you drain out.
