how long do propane rubber hoses last?
mackaycamp
trailer has not been used for 6 years. use it as a guest room.
want to get it back on the road and I am replacing things like tires, batteries, and anything else I need. Should I change propane hoses?
Thanks
Bud
17 REPLIES 17
Timtation
westend wrote:
I'd vote for replacing the hose. They can fail internally and will be a head-scratching mess to diagnose as an issue with the propane system. $15 will buy peace of mind.
This seems like a been there done that recommendation that should be put in some archive of Oldies but Goldies, a list of It's faster and cheaper to do this than determine IF. Perhaps a new permanent heading?
eichacsj
westend wrote:
eichacsj wrote:
Here in AZ where it sits full time in the sun I usually have to replace them every year. I see if they flex and when I hear hissing so I replace them. Couple of years on the regulator.
There only a couple of dollars so not worth getting up to the remote camping spot and find out the tank drained going up there. So every year now I change them.
Have you tried a cover on them? Something like this Techflex Flexo pet might save you a few dollars.
Then again, I've been in AZ in the Summer and ol Sol bakes a lot of stuff.
This AF 30u they are covered, they sit in a compartment in the front cap. Also I cover the whole TT with the ADCO premium cover during the summer. When I uncover one of the the first things I do is replace the lines
Where they fail is the factory connection at the line to the fitting, they just loose there seal, dry out is the way I would describe it. If you try to bend them they actually crack.
2014 Arctic Fox 30U
2001 Silverado 2500 HD, 4WD
8.1 Vortec / 4.10 gears / ATS Stage 2 Allison Transmission with Co-Pilot
Tekonsha Prodigy P2 Brake Controller
Reece Class 5 Hitch with 1700lb bars
Huntindog
X2 I carry spares as mine don't last very long either. Been looking for a higher quality brand. I also carry a spare regulator.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
westend
'03 F-250 4x4 CC
eichacsj
2014 Arctic Fox 30U
Steamguy
There's also an O-ring on the fitting that screws into the tank that can go bad. With 12 years on our old trailer, I found a problem with one, so I disconnected everything and took it to a fireplace/barbecue dealer. Walked out with everything new and ready to reinstall for about $50-$60.
Much easier than trying to puzzle out hoses and stuff at a big box store.
Need-A-Vacation
austex wrote:
Need-A-Vacation wrote:
Check the dates on the propane tanks also. Need to be recertified after 12yrs. A propane place near me will do inspect for free with a fill, maybe you have a similar propane place.
I think this should say 'recertified', yes?
Now that was funny!!! Lol
YES, recertified!!!
Bubba J- '13 Chevy Silverado 2500HD LT CCSB 4x4 6.0
'16 Jay Flight 32 BHDS ELITE 32 BHDS Mods Reese DC HP
WDH Set Up. How a WDH Works. CAT Scale How To.
westend
'03 F-250 4x4 CC
austex
Check the dates on the propane tanks also. Need to be decertified after 12yrs. A propane place near me will do inspect for free with a fill, maybe you have a similar propane place.
Tom & Jessie
Central Texas
MVPRV(RIP) Coast 26LRBS TT
Need-A-Vacation
Bud,
I think our first trailer was a little over 20yrs old when the propane hoses needed replacing. But that was here in Mi. Best thing to do is get some soapy water and turn the propane on to pressurize the lines, then spray/ soap all the hoses, lines, and fittings. Have someone ready to shut the tank off if you find a leak under the trailer. Of course, keep all flames away! ๐Ÿ™‚
Also go through the wheel bearings and brakes. Sanitize the water system. Inspect the roof, reseal it. May not leak now, but probably will once the trailer is moved.
Good luck!
BB,
Sounds like you may need new hoses! Take them to a propane dealer and they can make new ones for you. As for the tank fitting, I believe all new tanks have the outside thread which do not require a wrench to tighten. Matter of preference. I had the (green- mine were black from what I recall???) "outside" fitting put in for convenience. I can't recall the fitting "name".
bbaker2001
just purchased 2001 cardinal.
hoses look a little brittle. are there different types of hoses. someone told me not to use the hose with green connector, use the old brass connector.
also how about changing regulator
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
wannavolunteerF
You should give them a good look. My previous TT I replaced top 2 when I changed to auto-change regulator. Current TT, I had to change lower hose at 3 years old, as a squirrel decided it was wonderful for gnawing on.
2015 FR Georgetown 378TS
RVcircus
If they're no longer flexible I'd replace them. Last year I replaced the regulator and hoses in about 30 mins. It was cheap enough and I'd rather not risk a gas leak when on the road.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
scbwr
Go by condition of the hoses. Have they been kept under a propane tank cover? If they look questionable, replace them. Want real peace of mine? Replace them anyway!!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
