May-27-2020 11:43 AM
May-27-2020 08:48 PM
May-27-2020 06:54 PM
Kayteg1 wrote:maria_bettina wrote:
( No can do a gennie at this point; we are maxxed out on our payload. And really have nowhere to put it either.
The 1000W inverter generator weight about 25lb and takes less space than the battery.
If you will eliminate 1 battery having it, you have perfect solution.
With TC you can go several ways as technology is flooding us with new gizmos. You will find parallel thread how other member is trying to shave 3/4 tons of batteries from his TC and trailer rig.
Good luck finding the best for you solution.
May-27-2020 04:38 PM
May-27-2020 02:09 PM
cewillis wrote:
NRALIFR wrote:
Well,I would probably choose two group 27 or 31 AGM’s, and build a box that can double as a step up into the cab-over bed if possible. Those type batteries will fit in a step/box with a rise (height) that will feel normal to you when you are using the step. 6v golf cart batteries could be used if you want, But they are taller than the group 27 and 31 batteries, so if you made a step box for them, it would probably feel unusually tall to you.
Flooded batteries always need a sealed and vented compartment, but AGM’s aren’t as prone to that as wet cells. Technically, I believe all batteries can vent under the right conditions, but it’s pretty rare for AGM’s. They are more expensive than flooded deep cycle batteries, but if you compare quality flooded deep cycle to quality AGM deep cycle, they aren’t that much more.
srschang wrote:
For our use in the Northern U.S., 2-100 ah lithium batteries and 4-100 watt solar panels is a bit more than what we need. Spent a couple months traveling to Alaska and back last year, and didn't need to plug in the entire trip. We didn't have a generator. The batteries didn't charge from the truck either, as I have that wire disconnected. We did plug in a couple nights at campgrounds to run the a/c when it was too hot for us.
Our typical daily power usage:
- watch tv for 2-3 hours at night
- lights
- water pump for showers and stuff
- electric compressor fridge
- listen to music for an hour or so in the morning
- 3 or 4 cups coffee Keurig on the inverter every morning
- wife dries hair on the inverter every morning
Typically the batteries are at 60 - 70% in the morning before the solar starts charging them back up.
May-27-2020 01:46 PM
May-27-2020 01:43 PM
May-27-2020 01:32 PM
jimh425 wrote:
I don’t think you can have too many amp hours. You might also want to think about going Li-Ion so you can run the battery down to a lower percentage.
May-27-2020 12:45 PM
Kayteg1 wrote:
Aren't lithium batteries like $1000 a piece?
Personally I don't think you can count on solar panels for several days of camping. YOU NEED BACKUP GENERATOR.
Having generator and I bought 1000W inverter generator for $150 at HD, you can carry less batteries. End of the story.
NRALIFR wrote:
There’s no such thing as too many amp-hours.
My question would be, what are the dimensions of your battery compartment and go from there, filling it with the most deep cycle amp hours your wallet can stand. Consider all battery types; 6v, 12v, flooded, AGM, and even lithium if you can afford them.
You should ensure you have a battery charger that supports the type of battery you choose as well
May-27-2020 12:39 PM
May-27-2020 12:24 PM
May-27-2020 11:57 AM
jimh425 wrote:
I think they mean .8Ah for the circuitry/board of the Dometic frig and it runs on propane.
We’ve found that we can easily make an entire weekend with our 2 normal batteries in one spot if we run the generator about an hour each day. If we are moving around like at Yellowstone, we almost never have to run the generator. Changing to all LED lights made a huge difference. Also, keep in mind that newer tvs use a lot less power.
May-27-2020 11:56 AM
Kayteg1 wrote:
You are listing like 100 variables and you want solid answer?
I hope not?
I camp with single battery just fine and I make HUGE cup of coffee every morning on inverter power.
But then I usually drive the same day, or start generator for AC operation.
In your list I see electric refrigerator. Would you camp in area with triple digit temperature, or with fridge side facing south the poor thing will run 100% of the time. For that alone you need 200AH battery bank and probably bigger solar than you already have + backup generator for cloudy days.
BTW is the fridge really running on 0.8 amp?
May-27-2020 11:53 AM
May-27-2020 11:49 AM
