โMar-13-2023 09:03 AM
โMar-15-2023 03:04 PM
DallasSteve wrote:
Jayco customer service sent me information about installing a backup camera in my trailer. Here is the dealer's photo of that area. I can't tell if they installed a camera or it's just the mounting bracket. I've sent a message to my salesman to ask about it. The current version of the Furrion backup camera is about $500 with the video monitor for the truck. Is there a more affordable solution I should consider? I've read that some can work with a cell phone.
โMar-15-2023 12:33 PM
โMar-15-2023 12:31 PM
MFL wrote:ford truck guy wrote:
^^^ NO splicing of wires ( that I know of ) . everything should be plug and play with the aftermarket controllers... There are folks on here that say the aftermarket ( Prodigy ) controllers are better than the IBC......
Hey Joe...this is a pic of the Ford controller harness, that came in the glove box. One end plugs into dash wiring, the other needs spliced to controller wires.
I helped a friend, just 2 years ago, that had ordered a Tekonsha Voyager, and a plug/play harness he ordered from e-trailer, that he tried to install in his F150. It fit, but did not work. I asked if he had the Ford one, pictured, and he did. I connected the marked wiring to the Voyager, worked just fine.
Anyway, if the OP can get the Ford IBC installed easily, that is what I'd do. If he chooses to use the P3, can't go wrong there either, should work great.
Jerry
โMar-15-2023 09:35 AM
โMar-15-2023 08:00 AM
โMar-15-2023 07:50 AM
โMar-15-2023 03:28 AM
DallasSteve wrote:
Thanks for that tip. I haven't seen that key. I'm going to search for it and if I don't find it I will call my salesman to see if he knows where it is. I don't need it yet, but you never know when it might happen. In your situation wasn't calling a locksmith an option?
โMar-14-2023 07:06 PM
valhalla360 wrote:Grit dog wrote:
You might be surprised to find the 3rd connector is for plugging in the tool to lower the spare tireโฆ.
Not sure if Ford came to their senses but practice lowering the spare tire to make sure you have everything.
Ours had a special key...which was missing. This makes it impossible to get the spare out with the flat kit. Ford dealers couldn't get me a new key. Took 2hr to cut it free and then repair the cable.
โMar-14-2023 06:58 PM
โMar-14-2023 04:52 PM
โMar-14-2023 04:51 PM
ford truck guy wrote:DallasSteve wrote:
I hope I can get some helpful tips on the trailer brakes.
The Jayco information says the trailer has "electric, self-adjusting brakes". I just confirmed that my F-250 does not have the Integrated Trailer Brake Controller. I bought a more basic F-250 XL. I'm happy that it has power windows and cruise control. Can someone explain how the trailer brakes work and what I should do if I don't have the ITBC? I'm reading some places say they won't work at all without the controller. One website says "the 7-pin trailer plugin controls the brake lights, it doesn't engage the trailer's brakes". So it sounds like I need to add a brake controller. Should I take it to Ford and pay extra to add that or just buy something off Amazon and add it myself? Does it require another wire back to the trailer or does it work off bluetooth? Help!
Not sure if a dealer can add the IBC after the fact, but that's Okay.... go get yourself a Prodigy P3 or similar .... That controller can be added by anyone who is the least bit handy..
The 7 pin does control the trailer brakes, once a brake controller is installed.... There is a BLUE wire that will run to the controller, when you step on the brakes, that wire will energize the trailer brake system.
here - click
โMar-14-2023 04:40 PM
here - click
โMar-14-2023 04:26 PM
โMar-14-2023 04:01 PM
