interest question
randy1953
What do any of you guys use to protect your travel trailer cover from the sharp edges and overhang of the corner gutter drain extensions?
5 REPLIES 5
danimal53
rbpru wrote:
I use the split foam tube design for hot water pipes, folded over and duct taped in place.
plumbers call this "donkey d!#k" (at least the ones i know do). seems a perfect solution for protecting corners.
2010 Jeep Liberty Sport 4x4
2016 Coachman Clipper 17BH
eichacsj
Tennis balls
2014 Arctic Fox 30U
2001 Silverado 2500 HD, 4WD
8.1 Vortec / 4.10 gears / ATS Stage 2 Allison Transmission with Co-Pilot
Tekonsha Prodigy P2 Brake Controller
Reece Class 5 Hitch with 1700lb bars
rbpru
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
SoundGuy
Foam pipe wrap held in place with clear duct tape, Reflectix wrapped around the lower edges of the trailer body and each end of the awing, also held in place with clear duct tape. Been doing this for years, works like a charm with little expense. :B
2012 Silverado 1500 Crew Cab
schlep1967
Many use Tennis Balls with a slit in them put over the gutter extensions
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
