Interesting winterizing question.
Freeman2004
So, returning to the forums after too long of a break.
We lost out popup to water damage and are picking up our first tt on Saturday.
Due to the above, I never had to winterize a black or grey tank.
Just how does one do this? They are never really totally empty.
Scott & Karen
2002 Layton Scout 251
2004 GMC Envoy, a Burgundy Beauty.
7 REPLIES 7
Dennis12
aftermath X2
Dennis Hoppert
aftermath
JaredWPhillips wrote:
Personally, I drain them as much as possible. Then I dump a gallon or so of antifreeze into each tank.
This is overkill. Once the tanks are empty, all you really need to do is pour the pink stuff into the sink traps, shower traps and then into the toilet. The extra will flow into the empty tanks and collect at the valve. Nothing is going to freeze. The traps will be safe as well as the toilet flusher and the waste valves. You can pour gallons down the tanks but you don't really need to do this. I have followed this method since 2000 and haven't had any trouble.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Lwiddis
X2 Jaredโ€™s post.
SoundGuy
I know you said "black or grey tank" but is that what you really mean, just the tanks? If so, there really isn't any winterizing to do as residual antifreeze left over from wintering the trailer's fresh water system will end up in the grey & black tanks anyway and work it's way down to the waste gates.
2012 Silverado 1500 Crew Cab
Freeman2004
Thanks. Good to know.
Gotta relearn this entire process before we hit freezing.
Scott & Karen
JaredWPhillips
The only area that could be damaged by freezing would be the valves, so a gallon of antifreeze into each tank will ensure that the antifreeze flows down to the valve areas.
The tank will not freeze and bust; the only way that would be possible is if it was full of water.
MY RVing BLOG
  • 2002 Chevy Suburban Z71 5.3 V8
  • 2001 Chevy Silverado 1500 ext cab 4x4 5.3 V8. GoodYear Wrangler Authority E-Rated tires, FireStone AirBags.
  • TT: 2010 KZ Spree 240 BHS
JaredWPhillips
MY RVing BLOG
