Aug-14-2019 03:31 PM
Aug-17-2019 11:39 AM
Aug-17-2019 09:15 AM
Kayteg1 wrote:
I do have the same MY Lance and if you read Lance forum, the design has one of the best floor plans on the market, but engineering left weak point, what is the front corner under the slide.
Where you have metal channel under the slide and metal chanel in vertical corner, where the jacks bolt, those channels are not connected and all what holds that critical corner is some staples over the wood.
Once that has been repair, you will enjoy the camper.
On Lance forum you will find several member who loved the design so much, that after the original frame rotted, they spend (probably more than original price) on full rebuild.
Any dually will be fine for it. This is one of the lightest 12-footers with slide on the market.
Also check the wood above the slide as on mine - the awning had screws applied with no sealer and the holes allow for water penetration.
Aug-15-2019 06:45 PM
Aug-15-2019 08:29 AM
Aug-15-2019 06:30 AM
Aug-14-2019 04:45 PM
