Jayco vs Grand Design
ChrispyjCSLT22
New to this forum and this will be my very first travel trailer. All perspectives welcomed and appreciated.. After the Tampa show, these are the 2 I like the most.. The Rep said GD uses OSB vs we use plywood and he feels that because of this, GD is less quailty.. I thought it would be best to try and ask actual Jayco owners.. Thoughts between these 2?
https://www.youtube.com/watch?v=AxHlBhwduwQ
****VS****
https://www.youtube.com/watch?v=jLsoi9LtYWQ
Check out this brand new Travel Trailer! The 2024 Grand Design Imagine XLS 17MKE is one of the top selling imagine floor plans, it is under 5000lbs and 22'! More Info on this Travel Trailer! ▶ https://www.bullyanrvs.com/product/new-2024-grand-design-imagine-xls-17mke-2313923-29 Comment below or ...
CHECK OUT: 2024 Jayco Jay Feather 19MRK Vogt RV Inventory: https://www.vogtrv.com/ Leisure RV Center of Houston Inventory: https://www.leisurervcenter.com/ Airstream of DFW Inventory: https://www.airstreamdfw.com/ CONNECT: YouTube Channel: http://www.youtube.com/c/VogtRVCenter Facebook: ...
22 REPLIES 22
StirCrazy
Nomad III
Nomad III
Plywood is not higher quality compared to the proper OSB, I would take a outside rated OSB over plywood any day, its stronger (for the same thickness) way way more resistand to delamanation due to moisture, water proof resin/glues to make it, more dimentionaly stable than plywood, its cheeper, and more enviormentaly friendly.  there is a reason OSB has been replaced plywood, in every part of building construction.
for me it is about finding the floor plan you can use for a long time.  most of the reasons people buy new rv's is because the floor plan no longer works, weather it is because they have kids, get rid of kids or it just doesnt work like they thought it would..  take your time to figure out what you need for your situation, then look at anything besides jayco 😁  seriously though, look at the quality of the interior stuff, like the kitchan drawer construction, the trip work and cabnets..
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
I'm getting mixed reviews.. you say OSB, other say Plywood..  What gets me about GD is OSB, Luan, NO azdel, lippert frames while Jayco, plywood, Azdel double sided,  BAL Norco frames with the huckbolts and jayco cost less than Grand Design..
The next time I check out a jayco, I'll look at the interior cabintry and drawers...  however I must say, the 2 Wawa gas stations being built here,  plywood was used around the building and on the roof decking...  it just seems GD is using cheaper materials and charging more
ya its debatable whats better in some peoples minds, its all enginered wood, Exterior OSB is more resistant to mositure and resists delamanating better. you can get exterior grade plywood, but realy I don't think the extra cost warents it.  it costs more only because it uses thin sheets of wood, not because it is superior, just  a more expensive process.   I guess it depends where you live on weather you see more OSB or more Plywood, if the builder gets a good deal on plywood it might be cheeper, but generaly you can go thiner with the same strength with osb over plywood, although because it costs less to start with I would be tempted to go thicker on the floor.  OSB weighs more than the same thickness of plywood also so that could be a factor also a company spending a bit more to save weight at the sacrafice of water resistance and strenght.  I used OSB instead of drywall to do the inside of my shop, I couldnt believe how heavy it actualy was compart to some plywood I had laying around.
2016 Cougar 330RBK
patperry2766
Since it's your first trailer, do alot of soul searching about how you're really gonna use it and be honest with yourself about how often you're really going to be able to use it. 99% of RVs spend their life in the driveway or storage facility because people have to work, and when the weekend rolls around, there's always something to catch up on. Mine sat in my driveway for the last (3) years untouched because life often got in the way, plus somewhat of a changing lifestyle...motorcycles.
Things to think about:
What is your tow vehicle
How often will you use it, maybe an occasional weekend and 1-2 weeks over the summer
What outdoor activities do you participate in that will complement having a RV, and what will compete with it
How far will you travel. Will you be staying local or alot of cross country trips? Gas gets expensive
Will it be something you sleep in primarily, or someplace that you park and don't want to leave the confines of the trailer
Will you be primarily staying in campgrounds that have facilities (shower, bathrooms, electric) or more boondocking where you're on your own
Alot of questions to think about. Most people buy their 1st camper only to become quickly aware of what they actually needed instead of what they thought they wanted. Also, alot of times, you might not really know what features are important until you get out a couple of times and either don't have it with you, or never actually use it. We did that, so that's why were in the market again
Courage is the feeling you have right before you fully understand the situation
Well, I sold my motorcycle to buy one..  I work 2 jobs.. my main is from home and PT at a electronics boutique.... my plan is to work from it at least 1-2 weeks a month, then take a week or 2 vacay during the summer and 1 during the fall..
my outdoor activties are hiking, pedal biking, exploring.  my tow vehicle is a 2022 Silverado LT with the 2.7 High Output turbo 4 beater..
patperry2766
GD has slid alot since they were bought out by Winnebago, Jayco not so much. However, I wouldn't buy either of them personally. Look at either Northwood Mfg or Outdoors RV Mfg out of Oregon, Lance or Alliance...but nothing is perfect.
https://www.youtube.com/@undercoverrvtech
This guy has some good content and things to help you make a better purchase decision. Good Luck
All those RVs you listed are pretty darn pimp..  I watch some of Thompsons RV in Pennalton OR (spelling) and those rigs are supper nice.. I like the alliance and the lance as well and would love to own a Nash from NW MFG but I have to be real.. I'm broke and on a tight budget(Thx Joe) and those rigs are just way out of my prince range and I live the Southeast and Outdoors and NW aren't available in my area.
I respect  your opinion that you wouldn't buy either, but if you were force to choose which would you pick?
According to Joe, the economy is doing great and we're all wrong and that we should be thankful that he has brought inflation down from the 9% when he took the reigns. HAHAHA. I wouldn't but any of them to be honest. We're casually looking, and this is what we've been most impressed with so far. Not the biggest or flashiest by far, but probably one of the best built ones on the market now.
https://www.opuscamper.us/op-15/
Oh, ok... yeah I'm gonna enjoy 8.9-10.9 interest rates under Bidenomics vs it was 3.85 under the other guy, right now I'm enjoying 4 pack chicken thighs raw from Publix was $4, now $11, gas was 2.28 now above 3.50, the list goes on 🙄🙄😁
anyway, that was a stud of a RV you sent me..  it looks bulletproof and expensive. you should go for it, but **bleep**..  the op17 would be my pick
What's your budget and how many people will be going with you?
Mostly me, with possibly one more...  budget is 30K or less, but preferred to only finance 25K
InTech Flyer, either the Discoverer or Forge. There're not the flashiest on the inside but solid built trailers at a really good price point. https://intech.com/rv/flyer/
I will check them out today.. I fell asleep last night. ty for the suggestions
QCMan
Nomad III
Nomad III
No personal preference here but some advice. First, look at the frame height. That will tell you how rigid the trailer will be. A 4" frame is fine for a single axle but awful for two axles due to flex. Whatever you end up with, make sure you get and take a video of the pre delivery inspection. No question is silly and if the person giving the pdi won't/can't answer a question, do not proceed with the inspection until someone can give you an answer. It would also be helpful if you had someone who was familiar with travel trailers along with you for the pdi.
 Be aware that perfect trailers right out of the factory are as rare as hens teeth. A good prep crew will take care of issues before you get there but there will always be something either at the pdi or after. Minor issues after delivery are best when done by you as even something minor like a bad shade can put your unit on a dealers lot for months at a time. This is one hobby that can make a handyperson out of you or use your skills to do better than the designers.
 Some info on OSB: it is used in most high end homes due to the inherent stability.
 Never let the small stuff ruin a trip.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
