Keystone 22RBS slide topper
QCMan
Nomad III
Nomad III
Does anybody have a slide topper installed on their Keystone 22RBS? If so, where is the rail installed on the trailer side. Seems that Keystone has no clue on where the backer is on the trailer even though they know exactly where it is on the slide. Thanks for any help on this!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
3 REPLIES 3
QCMan
Nomad III
Nomad III
Found the answer. It is installed now.
kellem
On my 2020 Keystone Outback, it would require some fabrication of the slide faceplate to accommodate a topper.
TUCQUALA
Don't have a Keystone, but I would put the body rail up as high as the roof line allows. More slope, the better. Some trailers (like our old Jayco) have a drip rail mounted just above the slide. If you have that, you could remove and put the awning rail where that was. But, I think the best place is just below the roof drip mldg. There is sufficient construction in that area to attach to and, again, gets the most slope out of the awning fabric.
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
