Lance 815 shower bypass
Tony1978
Hi, My Lance 815 only has a 10 gallon black water holding tank and the shower water goes into it. I have heard of people installing a bypass valve so you can choose to drain the water directly to the ground or you can switch it back to continue using the black water holding tank. I'm strictly a boondocker so having this option would be great.
17 REPLIES 17
Reddog1
There are several ways to get the "Y" in there. Gray water is much easier to plumb than black.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Tony1978
Thanks a lot red. If I can fit that directional Y in there I can picture exactly what you mean. I really appreciate your help on this.
Reddog1
As I understand your question, you can install a bypass valve if you have the
Welcome to the RV.NET Forum
If I understand, you can split the gray water from the holding tank if you have the space for the plumbing. Simply stated, you have to disconnect your gray plumbing from your holding tank. Install a "Y", with a directional valve, or two gray dump valves. Probably easiest with the two gray dump valves. Connect one of the dump valves to the holding tank. Add a dump connector to the second gray dump valve. Ideally, the gray dump valves will be higher than your holding tank. This will prevent back flow if you open the gray dump valve to dump connector without closing the gray dump valve to the black tank first.
Wayne
Toad: 91 Zuke
