Lance 855/855S Battery Compartment Safety Issues
Mike_Stanbro
The following is from a paper I sent to the President of Lance Camper on January 15th of 2014. I have received no response of any kind from Lance and now feel it is appropriate to post this to the various Camper forums so that the consumers of their products are informed of what I consider to be a serious safety issue with the Lance 855/855S camper.
I would like to preface this post by saying that I have never taken the time to bring a product safety issue to the attention of a manufacturer before. I do so now as I am genuinely concerned about this. I don't just point out problems, I also make detailed suggestions on how to fix them. I do not seek any form of compensation. I do want Lance to respond to my claims.
I openly acknowledge that I have used a couple of pictures posted by another contributor to this forum who goes by the user name "skipro3" and I reference his post with a hyperlink in the document that I sent to Lance and in this post. I use his pictures as I had already repaired my camper before I got fired up enough to document my concerns and take any pictures of my own.
Please note that I don't use a fictitious user name on this forum, or any forum, as I believe in transparency.
Following is the content of the paper I sent to Lance.
Introduction
I recently purchased a Lance 855S camper. Most everything about the camper is excellent except the layout of the battery compartment. There are a number of issues about the battery compartment that I feel are worth documenting and are the reason I took the time to write this paper. In this paper I use 855 and 855S interchangeably as the battery compartments appear to be the same for both products.
First, let me say that I am an electrical engineer and I know that in any system design as complex as an RV, tradeoffs have to be made. An RV is essentially a small house that travels down the road. It is a significant design challenge and I have some appreciation for the kinds of tradeoffs that have to be made to satisfy all of the product requirements. That said, safety can never be compromised and the ability to access and service high-maintenance components of the RV should be high on the prioritized list of requirements.
When I look at the 855S as a whole, I see a great product in terms of comfort, features, and build quality, all in a light-weight package. I also see the following limitations which are no doubt tradeoffs due to weight and size requirements: limited outside accessible storage, relatively small holding tanks, and 20-lb propane bottles instead of 30-lb bottles. Another apparent tradeoff is the battery compartment. It must be a tradeoff as it is only accessible from the inside and is stuffed with so much other equipment that it makes access to the batteries extremely difficult. In addition, the batteries are in the same small compartment as the AC-to-DC converter which poses a safety hazard. I can get along with the other tradeoffs but the layout of the battery compartment and poor access to the batteries is so bad I feel compelled to document it. I discuss my perception of the safety and maintenance issues in separate sections of this paper.
Safety
Placing the batteries in the same small compartment as an AC-to-DC converter that makes the following statement in its installation manual is reckless and a product liability issue:
โ€œUnit is NOT ignition protected. Do not mount in the LP gas or the battery compartment.โ€
I am not making this up, see the outlined text of the scanned page from the PD4000 Power Control Center installation manual shown in Figure 1.
Figure 1: Scanned image of PD4000 Power Control Center installation manual.
Yes, the batteries are in battery boxes that are vented to the outside and I assume your engineers felt that was sufficient to prevent an accumulation of hydrogen gas in the compartment. I, however, do not agree. Here are some things to consider:
  • Flooded-cell lead-acid batteries, the type installed by my dealer and most dealers, out-gas during bulk charging. Bulk charging will occur whenever the batteries have been significantly discharged.
  • The batteries are vented to the outside through openings that are forward facing such that when traveling down the road there is positive pressure into the vents. The positive pressure will force any hydrogen gas to backflow into the compartment it shares with the AC-to-DC converter. The battery boxes are poorly sealed clamshells which cannot prevent leakage when positive pressure is applied.
  • It appears that Lance leaves it to the dealer to install the batteries and battery cables. Because of the difficulty in getting the battery covers off/on and the limited space to route the cables, the dealers tend to do a terrible job and hack up the battery box covers creating gaping holes from which hydrogen gas can easily leak. Figures 2 and 3 below are photos of one dealerโ€™s hatchet job. Clearly, this is NOT SAFE.
Figure 2: Close up of gaping hole in one battery cover. Safe?
Figure 3: View showing battery boxes in the same compartment as AC-to-DC converter and forward facing vents.
For more details and more photos of this ownerโ€™s experience, refer to the following post on the RV.net forum:
Wiring issues with my 2012 Lance 855S
My dealer did an equally poor job but in different ways. The holes in the battery covers were not huge slots like those in the previous photos; instead, the holes were not quite big enough to accommodate the rubber grommets so they simply left the grommets off which resulted in a wide gap between the cable and the hole in the cover โ€“ more than enough for gas to leak from. In addition, the lugs on the battery cables were so poorly crimped that several of them literally fell off when I attempted to reconnect them. Furthermore, the cables were made from #2 AWG house wire which is very stiff and difficult to work with and the cables were about three feet too long. Needless to say I threw those cables overboard and built new ones from fine-strand #2 automotive cable, cut to length, with soldered-on lugs.
Even if the battery covers are not molested by the dealer, they are poorly sealed at the junction between the top and bottom portion of the clamshell. From the experience of the owner who wrote the forum post and from my own experience, the dealers are having a difficult time installing all the screws that hold the clamshells together due to the cramped quarters. In particular the screws on the far right side of the right-hand battery box are nearly impossible to get to. Try as I might, I was not able to get one of those two screws installed.
But then, you might think to yourself that hydrogen gas is lighter than air and will therefore travel up and out the top of the battery box through the vent tube and it doesnโ€™t matter that screws are missing and the clamshells donโ€™t seal well. Right? Maybe not . . . consider the following sequence of events which I submit are a typical usage scenario of a truck camper and will possibly results in an explosion or fire:
  • The camper has been taken off of the truck and lowered as low as possible to aid entry at the campsite.
  • In preparation for departure from the campsite, the camper is raised up and loaded onto the truck during which the jacks are run nearly to their upper limit. This imposes a large drain on the batteries and they will need to be recharged.
  • The camperโ€™s electrical cord is plugged into the truckโ€™s 12V electrical system.
  • The truck and camper travel down the road.
  • While traveling, positive pressure from the wind created by the truckโ€™s movement is hitting the forward-facing battery vents.
  • Also while traveling, the electrical system of the truck is charging the batteries.
  • Due to charging, hydrogen gas bubbles out of the battery and is pushed outward into the small battery compartment due to the positive pressure on the battery vents and the poorly sealed battery boxes.
  • The truck and camper arrive at their destination and the camper is plugged into AC shore power which energies the AC-to-DC converter which is specified as being โ€œNOT ignition protectedโ€.
  • Boom ... an explosion and/or fire occurs due to the highly flammable hydrogen gas that has built up in the battery compartment.
Unless I am way off in my reasoning, this is a significant product liability issue and needs to be taken very seriously. This is especially true when you consider how badly the battery covers are being molested by some dealers.
As I see it, there are several things that can be done to help mitigate this problem. Here are some of the things I have thought of.
  • Only install AGM type batteries as they are reported to out-gas much less during charging.
  • Pre-install the batteries and pre-route the cables at the factory to prevent the dealer from doing the kind of hatchet job shown in the photos.
  • Vent the batteries in such a way that the vents are exposed to only negative pressure (vacuum) when traveling. This would require that the vents be side or rear facing.
  • Move the AC-to-DC converter to another compartment.
AGM batteries pre-installed and pre-wired from the factory is likely the easiest solution. It is my understanding that AGM batteries have zero maintenance which would help with the issues I raise in the Maintenance section. It is also my understanding that AGM batteries out-gas much less during charging. I am not an expert on battery chemistry so will defer to others to verify the accuracy of those statements.
Maintenance
In addition to the new Lance camper, I currently own a boat and a 5th-wheel RV. In the past I have owned two other boats and one other RV. As such, I have a fair amount of experience with maintaining batteries in battery boxes. I have never experienced such limited battery access as in the 855 and I have never had such difficulty in taking the cover off of a battery box. There is simply too much stuff inside the battery compartment. In particular, the controller board that runs the jacks gets in the way of removing the right-side battery cover. You can somewhat see this in Figure 3. Unfortunately, the maintenance of flooded-cell batteries can be a recurring task during periods of heavy use and the ability to access the batteries for water replenishment is important.
I was afraid that I was going to rip a wire loose from the controller board or tear the furnace duct tube in the process of removing the battery cover. As mentioned earlier, it is nearly impossible to access the right-most screws on the right-hand battery box cover. Wow, what a painful experience! Then I had to figure out how to get it all back together โ€“ an equally painful experience! I swore profusely and had to walk away a few times to cool down.
Honestly, I have never seen such a terrible layout. The technician who did the battery installation at my dealer had a very negative opinion about the battery compartment when he gave me the pre-delivery walk-through. I didnโ€™t fully appreciate what he was saying until I had a chance to experience it firsthand. I quickly came to share his opinion. We are not alone โ€“ there are many mentions of the 855 battery compartment on the RV.net and Lance Ownerโ€™s forums. Several people have posted that they decided against purchasing an 855 because of it.
I have a few ideas on what might be done to make things better.
  • Factory install AGM batteries which have zero maintenance or factory install flooded-cell batteries with a battery watering system so they can be maintained without having to take the battery covers off. That way the battery covers only have to be removed every five years or more when the old batteries are changed out for new ones.
  • Place a door on the front side of the camper that provides access to the batteries from the outside. It would be much easier to get the battery covers off if they could go forward and out a door.
  • As long as you are at it donโ€™t just put a door, put a slide-out tray. Make it an option and charge for it. I know I would pay for it.
  • As the screws that hold the two halves of the battery boxes together are difficult to access, install battery boxes that use a strap instead of screws.
  • Move the jack controller board to another location or have Atwood redesign it such that it is smaller and can be located in an up-down orientation. The current slanted orientation and large size is the main source of the maintenance access problems.
  • Raise the height of the compartment another inch and/or extend it another inch so that the jack controller board can be located at a better angle and avoid interference with the battery box cover.
  • Get rid of the excess 20 ft. of telephone cable inside the compartment. That was one of the first things I did as it tends to get in the way. Surely you can get that cable built to a custom length.
Conclusion
All complex systems have tradeoffs in design but safety must always come first. Maintenance of flooded-cell batteries can be a frequent task during periods of heavy use and the ability to access the batteries for water replenishment is critical. At it is, the battery compartment of the 855 product is a maintenance headache and a product liability lawsuit in the making. It is a blemish on an otherwise outstanding product. People are talking about it on the forums and their words are quickly spreading. Sales have been lost because of it.
Mike Stanbro
Portland, OR
121 REPLIES 121
JumboJet
sleepy wrote:
JumboJet... I know that you did it correctly... it's been a long time since I've seen anyone crimp and solder the lugs. You were trained well and know your stuff. We should all be so lucky. I would proudly follow your lead.
I bought my finely stranded copper wire from an audio shop for the few electrical projects that I have taken on. Inverters and PVSolar, multiple batteries, the trimetric shunt, etc.
I too use the shortest possible wires, crimp and solder the lugs.
Thanks
The entire time I was working with the 2 gauge AWG I was thinking I would really prefer to be working with some 2 gauge welding cable. I went on line to one of my favorite websites (McMaster Carr) and they have 2 gauge welding cable in both red and black. A little pricy, but for a job done right I don't mind spending a little extra. Next time.......
sleepy
JumboJet wrote:
sleepy wrote:
JumboJet wrote:
Those cables,like most wire terminations are custom made at Lance. With the price of copper, I can't see why they waste so much wire.
I actually saw wiring harnesses that were shipped in by vendors being unloaded when we were on a tour of the Lance factor a few years ago.
Note: You will find unused wires in your wiring harness too
I guess they are custom made somewhere - one size to fit many different campers. I did a better job crimping the ends than the supplier to Lance does and then I completed the job by filling the lugs with solder.
I have been very lucky, my guru is bigfootford... Jim has given me very good advice and guidance over the years... I do exactly what he tells me. I never fail to credit him for a job well done even if it's my hands doing the work.
I bought my finely stranded copper wire from an audio shop for the few electricl projects that I have taken on. Inverters and PVSolar, multiple batteries, the trimetric shunt, etc.
Thanks
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
JumboJet
Ski_Pro_3
$75 installed is a good price. Especially considering one's personal tool supply and mechanical skills. I used the opportunity to justify buying the saber/jig saw! Ha!
narcodog
When My friend bought his 855s last July the dealer offered to instal a second door for him for $75.00. They stated it was an unadvertised option.
Mike_Stanbro
skipro3 wrote:
Also, think about adding the compartment door to access the storage under the front dinette seat from the outside. The contributor Skipro3 documented the "how-to" for that.
Hey Mike, Lance stole my idea and the 2014's have the additional storage door from the factory.
I notice that the windows slide different too.
That is interesting as I have a 2014 model and it did not come with the second exterior door. Lance must have liked your idea as much as the rest of us.
I cut the hole out for the second door on my camper but the weather has been too cold and wet for RTV to seal properly. Tomorrow I am taking it to a local RV repair shop that has a heated indoor shop. They said they would charge me an hour of labor ($88) to install a back frame and screw/glue/seal the door.
I believe the windows shown in the picture you attached are the single pane variety. Most campers are being ordered with the dual-pane windows.
Mike Stanbro
Portland, OR
kerry4951
skipro3
You can bet your booties that these companies do monitor these forums, they just don't say much. But in this case, Im sure they saw what you did by adding the outside storage door and decided to add this to the newer campers. If you ask them though, they will give credit to their elite team of in house engineers for coming up with the idea.
2009 Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilsteins, Hellwig Sway Bar.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, baseboard and Cat 3 heat, 2nd dinette TV, cabover headboard storage, 67 TC mods
sleepy
JumboJet wrote:
donnyb wrote:
The battery cable wiring was that stiff crap, including loose terminal lug crimps.
I just replaced my batteries (Always use sealed batteries preferably AGMs) and while I was at it I shortened those 2 gauge AWG cables. I went to the auto parts store and purchased new copper lugs. I crimped them and then filled with solder. I just didn't see the need for 30" cables where a 12" cable would work.
It may be cheaper to use only one length of battey cables than to try to store many sizes and possible install one that is too short in a different model camper than it is intended for.
I was surprised when we watched many various model campers going down the line at the same time. They had two types of assembly lines at the time... wood frames and aluminum frames.
(I have a feeling that a lot of components are made up in low wage countries.)
JumboJet
Ski_Pro_3
Mike_Stanbro
donnyb wrote:
Wow Mike, I could have written that first post & comments of yours myself ! Exactly the same experience ! I just took delivery of my own 2014 Lance 855s and decided to pop open the batteries to check the water level. I was just as stunned as you were to see the sloppy holes in the battery box tops, and the impossible access to the batteries. It took me 2 hours to get access to the batteries & add water. And by the way, they did indeed need water. Every cell was low. The battery cable wiring was that stiff crap, including loose terminal lug crimps. Wow I feel like we must have bought from the same dealer....
Yeah, I think it is safe to say this is an endemic problem. Too bad too, cause it is a nice RV otherwise. Look into AGM batteries.
Mike Stanbro
Portland, OR
donnyb
DenverDoc
Interesting that I would find this thread today after having posted a forum note a few hours ago on the Lance Owners website regarding this exact issue of impossibly-difficult access to the batteries. I love the camper, but routine battery maintenance looks as if it will be a nightmare!
sleepy
Mike Stanbro wrote:
I just ordered a pair of Group 27 AGM batteries. They are made by NorthStar, have 90Ah capacity, and have the RV style threaded lugs. They are rated for over 400 cycles to 80% discharge. The part number is NSB-AGM27M.
The best price that I could find was $243, each, with free shipping.
I measured the battery boxes and Group 27 is the largest that will fit in my Lance 855S.
Mike, we all know that is a lot of money...
... but it's cheap when you consider that they will be maintainence free and the peace of mind that comes with them.
If you never discharge them below 50% you'll get 10 years or more out of them.
BTW... my Optimas group 31 DT's only have 75 AH... with solar panels, LEDs etc I seldem use more than 37 AH over night..
Good for you!
Mike_Stanbro
Mike Stanbro
Portland, OR
