Lance camper truck bed width opening question
specta
I have a 2011 Chevy 2500HD and the bed opening is 59".
What was the first year Lance made campers that fit that opening?
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
1 REPLY 1
burningman
1988 is the year most makers narrowed that clearance. Thatโ€™s the year Chevy narrowed their tailgate opening. (Dodge did it in โ€˜94 and Ford in โ€˜98.)
The clearance issue is usually only on one side, where thereโ€™s a little bump out in the area inside the bed behind the wheel well, for the camper bathroom.
You can modify an earlier camper to fit. That bump-out just needs to be trimmed down two or three inches. Often thereโ€™s enough space to do that without much effort.
On my โ€˜87 Vacationeer, the fiberglass wet-bath shell was right up against the inside of that bump-out section. I sliced the fiberglass and sectioned a couple inches out, then โ€˜glassed it back together.
If you fund a killer deal on a well-preserved older camper you really want, the tailgate clearance issue isnโ€™t a deal-breaker, and you can get it home in your newer truck, youโ€™ll just have to load it a little crooked and look like a dummy on the way home lol.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
