Leaking pipe
tmas
On my new trailer I have a leaking fitting. I have contacted the salesman, but wanted to see if any one had any fixes here. It appears the leak is on the fitting between the plastic tubing and male connector for the hot water.
2009 Silverado Crew Cab 5.3L
2014 Salem 28QBXL
12 REPLIES 12
beemerphile1
tmas wrote:
beemerphile1 wrote:
A pair of end cutters may be able to tighten that clamp, I've had success with them and it costs nothing to try.
What would those pliers be called? Trying to find some at Lowe's of Home Depot.
Not pliers, end cutters like I said originally.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
tmas
2014 Salem 28QBXL
6_7_tow_rig
downtheroad wrote:
smkettner wrote:
I would cut out the fitting and replace with Sharkbite or Gatorbite.
That white flex hose I would replace with a faucet supply line style fitting.
Home Depot or Lowes has it all.
Do what smkettner said....easy fix. Couple of bucks. Forget fooling with the dealer.
This..... much better to do little fixes like this yourself if you are handy. I tend to fix all these type of things myself so I know they are done right.
2018 Dodge Ram 2500 Laramie Cummins 4x4
2013 Primetime Lacrosse 318bhs
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
sljkansas
Don't use regular worm clamps, they can loosen up. I found out the hard way. Home Depot has simple PEX clamp tool you can but with out breaking the bank, and the clamps. Buy the tool and a package of clamps, they are easy to install. You may find you need one late at night, and you will have them. Also get a good pair of side cutter to remove the old clamps.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
beemerphile1
jimw606
Do you have a pressure regulator installed?
nomad297
This is leaking at the crimp -- not at the threads. If there's enough slack, cut the PEX at a nice round spot and replace the insert male adapter with a Sharkbite male adapter.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Ron_Nielson
Don't dismiss the possibility that the fitting itself is cracked.
path1
That should be a clue. . Once you get it that fixed, check all fittings you can and inspect wherever you can, to include connections at hot water tank. That should be "hot" side because it is red. Hot has a tenacity to wiggle loose before the cold IMO. Inspect wherever you can, they do come loose. Inspect all the places you can to include connection at hot water tank, toilet valve and under sinks, showers. You don't know which of the fittings will work its self loose. I mark mine with a felt tip pen, index line type of thing so the next time inspecting I could see if fitting was coming loose.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
time2roll
Rollnhome
Cut the clamp. Make sure plastic is not cracked. Retighten with Teflon tape on threads. Install new SS hose clamp. I'd do both. Doesn't look like much thread holding fitting. If new dealer should fix it, but that might be more trouble than the 30 minutes it would take you to do it.
2008 Discovery 40X towing a Jeep Grand Cherokee
