Letting a diesel sit
This is the first year my Diesel is now my tow vehicle and not my everyday runner... Besides keeping her plugged in (gets cold here in the northeast).. I will use it for snow removal as it has a plow but if it's like last year,,, no snow..Should I put anything extra in the tank besides my normal - Power Services Diesel Kleen + Cetane Boost.. Will probably sit from late October to May... Or so...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
20 REPLIES 20
bfast54
Well......I owned a 5.9 cummins....that sat up here, from end of oct.....thru middle of may........most of winter covered in 2...3 ft of snow,and when it melts.....I turn the key, and go.......never an issue.....for 5.6 years.
I bought my Powerstroke....day before Christmas last year,and it sat till May.....long winter here.......just change the oil in spring........good to go.
NEVER had a charger,maintainer.....on either......and we get real winters up here.
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
tvman44
All the above, but I would still start er up and drive a few miles every couple of weeks and keep a battery maintainer on it. ๐Ÿ™‚
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
mowermech
thomasmnile wrote:
Would addition of a biocide to a full tank of fuel and running the truck so treated fuel is in the entire fuel system be of benefit? 7 months of inactivity seems like a long time......
Is there water in your fuel tank?
Algae will only grow at the water/fuel interface. No water, no algae.
IMO, if there IS water in your tank, you should get the tank emptied and cleaned, then run the fuel through a filter/separator to remove any water and/or dirt.
With a clean tank and clean fuel, you should need no additives, especially if you fill the tank with winter blend fuel, and keep it full. An air space in the tank will allow condensation, and you don't want more water in there!
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
thomasmnile
uterep
and making sure your glow plugs are up to snuff
The_Mad_Norsky
The white bottle Power Service should help that diesel from gelling, although when it does start to get cold a topping off with #1 diesel will help.
I wouldn't put anything else in the tank.
One thing I have always done, since I have mostly lived on the northern great plains in the Dakotas where cold is king, is change the diesel fuel filters every fall. That way I have fresh filters for the coldest winter months.
Also be sure to check out the battery condition and make sure both are in top notch condition.
Those things done, you should be good to go.
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
