โJan-28-2020 06:22 PM
โJan-29-2020 06:01 AM
โJan-29-2020 04:11 AM
โJan-29-2020 03:59 AM
dodge guy wrote:
A 215 70 14 will be the same height as a 205 75 14, jus a bit wider.
With hat said I would only consider the Carlisle HD tires.
โJan-29-2020 03:57 AM
Huntindog wrote:BarryG20 wrote:??????
I also would look at the gy endurance
You might think about the 215 size instead of the 205 size as it gives you a bit more weight capacity and isnโt any larger diameter so should fit fine. Though not knowing the weight of your trailer you may not need any additional weight capacity cushion
All other specs being the same, a 215 WILL be taller than a 205.
Not saying it won't fit, or that it's a bad idea.... Just that it WILL be taller
โJan-29-2020 03:50 AM
โJan-29-2020 03:02 AM
โJan-29-2020 02:59 AM
MarkTwain wrote:
1. look at the side of the tire and look for numbers like "122/05" that is the week and year the tire was manufactured. Many RVers keep tires for about 5 years and then replace them.
2. Look at the possibility of switching to 15" rims for more tire capacity and stability.
3. I prefer to have the highest rated tire that will fit on my trailer i.e. G rated tires on my 15th. wheel..
โJan-29-2020 01:48 AM
โJan-29-2020 01:01 AM
โJan-28-2020 10:26 PM
Crushedstang50 wrote:
So, I have a 2007 Keystone Outback 23rs. The tires that are on it are 205/75R14's they are aged and looking worn. I would like to replace them with a better option. I know exactly squat about tires and load ranges ect.... What would be a good option to go with for replacements?
Thanks in advance!
โJan-28-2020 09:26 PM
โJan-28-2020 09:17 PM
โJan-28-2020 07:01 PM
โJan-28-2020 07:00 PM
