Looking for an as-built or owners manual for a 1995 Aljo Travel Trailer 30' with slide.
Kenneth2
My Mum just recently purchased a 1995 Aljo Travel Trailer 30' with slide and I am trying to repair some broken water lines and looking for where they are directed to make repairs. the one line above the rear left tire goes into a tee then goes up a wall and is broken.  Hoping for diagrams or info to reduce the amount of work to make repairs.
1 REPLY 1
QCMan
Nomad III
Nomad III
Sorry to say but there are not many cases of plumbing diagrams being available for current models and even fewer for 29 year old models. Just like plumbing in a house, the lines are usually made so they use the least amount of piping. Just like someone who bought a new trailer, you will have to trace the lines and where they go with no idea of where to begin. What type of lines are you trying to fix? Also, what do you think caused it? If it was frozen then every bit of piping is suspect along with valves and fixtures. If you think it is just the obvious break, go directly above the break inside. Chances are it goes straight up to a fixture. Not usually a lot of wasted length in an rv plumbing system.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
