Looking for backup camera for factory ford system
Crumm
Have a 2015 F350 with backup camera in the tailgate emblem. Handy little feature for hooking up trailers and backing up. Problem is when you pull the tailgate to load the camper the camera gets left at home in the garage. Is there a aftermarket camera option that plugs into the factory camera plug under the bed? Looking to mount it on camper rear bumper or maybe the back door.
2015 F350 SuperDuty, SC, LB Torklift hitch and tie-downs, LT285/75R18 Toyo AT II 4080@80psi
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS
16 REPLIES 16
TucsonJim
You could probably open up the tailgate to remove the camera and wire. Then build a suitable mount to relocate the factory camera. It doesn't look like it would be too tough.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Dakota98
I don't know if Ford has proprietary connectors or not, but if you can determine what type of connector you need, many camera manufacturer's sell cameras individually without having to purchase the monitor. Just get added length wiring and add it to the RV.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
