Misaligned shower door
wgriswold
We just got back from a trip and have several repairs that came up. Here is the first.
The shower door is not square with the frame. The door is cocked clockwise (while looking at it from the outside) so that the lower right corner rubs against the bottom frame and tears the gasket and then the shower leaks. The door drops about 1/8" or maybe a little more from left to right. I have to lift up on the handle to close the door. It went back to the dealer under warranty but the problem continues.
The trailer is a 2018 25Y Arctic Fox and the shower is made by SEA.
Here are the solutions I can think of:
1. I have directions on how to disassemble the frame and square it. I would have to essentially move the left part of the shower enclosure back into its frame and then reassemble while drilling new holes for the screws. The glass would have to be freed from its caulk to allow movement. I am reluctant to do this because I am afraid of causing more problems.
2. I could insert a washer or two on the bottom pin which the door rotates on. That might raise the door enough to clear the right lower corner. I might them have to apply a shower sweep to the inside of the door frame to prevent leaking at the lower right.
Has anyone else addressed this problem or have any suggestions?
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
3 REPLIES 3
gaymeadowsman
When we bought our 2014 Avenger, the glass for the shower door was cut almost 1/2 inch out of square. It was nearly impossible to keep it closed while in use. We went back to our dealer with it,under warranty. Prime Time told the shop Mgr. to "Deal with it." It took the threat of a letter to our State's AG to get a new enclosure.
John 😛
Ted :R
in search of the next one
2010 Chevy Silverado Ext Cab LT
2015 Chevrolet Impala LT
path1
SEA has a web site or used to with parts views. Shower Enclosures of America.
Those crazy showers dont look anything to complicated, but took a lot more time than I thought it would to replace squeegie piece at bottom of my 2013 AF.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Dave_in_TN
I have found that when my shower door is off like that it is a result of the rv not being level, or at least one corner may be lower creating some flex in the frame. Try adjusting corner jacks a bit and see if it brings the door into alignment.
Dave & Christy / 5 Awesome Girls (28,26,24, 18 and 16)
2021 Grand Design Solitude 378MBS
2019 Ford F-350 SRW 6.7
