Multi-Camera trailer wiring help needed
skripo
I am running 3 cameras to my tow vehicle using standard RCA hybrid wire. What would be the best connector to use to connect from the trailer to the tow vehicle?
I was thinking of repurposing the flat 4 connector but I am not sure if I can use a common ground for the shields.
All help welcomed.
2015 Fun Finder 242 BDS
12 REPLIES 12
skripo
Fortunately it is a lot easier now with the explosion in vehicle monitoring, especially for school and city busses.
I also decided to go twisted pair in the 'hope' that the cancellation of magnetic fields might somehow avoid issues. I also found a neat weatherproof connection for $7.00 that I ordered.
The values and connector should be here by the end of the month and I will do a huge write up.
Thanks for putting me on track!
rbturner
Glad it worked out. Sorry I did not answer sooner. I used standard flat 6 wire cable. The cameras were 6 wire cable output so I just continued that on. Then jury rigged/soldered RCA connectors to the video inputs under the dash. Then used RCA to F fittings to get me into the A/B switch that I use to switch between the trailer rear camera and the camera that watches the fiver hitch. The A/B switch feeds an old LCD TV that had a video input. For the audio; I just combined both camera feeds together and passed them right into the monitor/TV.
Keep in mind that this was all done with what was available in 2002.
skripo
You saved me metric s__t ton of wiring and money. I bought this to connect under my dash to my Lockpick Air V2. I will run one Cat6 to the rear of the car and terminate with a CAT6 flush mount junction box that I will mount on the receiver. I bought this one to mount on the trailer side.
Thank you so much for the help!
skripo
rbturner wrote:
I used a standard phone jack with 6 wire cable between our truck and trailer.
Standard twisted pair? How does the video look? Did you have to use Baluns?
I just found this mixed video Balun to RJ45. This is PURE genius!
rbturner
westend
There wouldn't be a lot of anything to gain by using the 4 way connector. You will need to get the signal from the trailer and through the truck to the monitor. The wiring for the four way would have to be cut close to the bumper of the truck.
XLR or balanced connectors have a lot of connection options and good wire is available almost everywhere. Alternately to that, the waterproof RCA cable would be my choice.
'03 F-250 4x4 CC
skripo
Beachums wrote:
RG6
I am not putting up a satellite, thats over kill. The siamese RG59 (video and 12V) is the industry standard for vehicle camera video.
skripo
Left, right, reverse. Each one is automatically selected by my Lockpick by using turn signals or going into reverse.
Video is displayed in my centre console when in use. Also have a wireless TPMS pressure and temp monitor displayed in my centre console.
Looks completely stock, slicker than snot.
Here is the latest thing I found:
http://www.campingworld.com/shopping/item/rear-view-camera-system-trailer-tow-quick-connect-disconnect-for-multiple-cameras/82556
Only really need one side for tow vehicle though.
ChooChooMan74
What is the purpose of 3 cameras?
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
Beachums
RG6
2004 Ford Expedition 4X4 3.73 w/quick shift kit
Reese DC Straight Line/ Prodigy P2 Controller
2010 Coleman CT 250 GS
skripo
I was hoping for something cleaner, something like this:
http://www.qualitymobilevideo.com/vosbhc5f.html
sch911
The flat 4 is not shielded. Why not just go with M/F RCA Jacks? There are waterproof versions out there...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
