May-17-2018 10:16 AM
May-23-2018 09:12 PM
Passin Thru wrote:
That's funny when I lived in S Californication you could go up 114 and over Tehachapi on 58 thus avoiding the Grapevine. Gosh! Has it changed that much?
May-23-2018 08:45 PM
May-22-2018 07:45 PM
falconbrother wrote:
My brother started out towing with a 4 Runner. He said it did OK. Struggled in the mountains. Now he has a Tundra. Does not struggle. They tow a 24 foot ultra light. Not sure of the weights.
May-22-2018 01:06 PM
May-21-2018 01:48 PM
May-21-2018 11:28 AM
May-21-2018 11:06 AM
RTCastillo wrote:gmw photos wrote:RTCastillo wrote:gmw photos wrote:
If the OP stated what year his 4runner is, I missed it.
But for example, looking at the 2012 4runner manual, it states on page 299, "If using a weight distributing hitch when towing, return the front axle to the same weight as before the trailer connection."
....so you are correct mister Speak, some of the specs change fron year to year.
https://cdn.dealereprocess.net/cdn/servicemanuals/toyota/2012-4runner.pdf
True! My own 4runner model says owner can use WD if we intend to tow above the recommended limits. Did not mention the new max though.
What year of 4runner is it ? Often a car manufacturer will state an upper limit without WD, and then a higher limit with WD.
To state that another way, Toyota might say 5000 lbs is the tow limit, but perhaps 3500 pounds just "on the ball" ( weight carrying ).
They may also state something like, "over 3000 lbs recommended to use a trailer with tandem axles". A "recommend" can likely be construed as different than a "limit".
An example for instance is like my old Nissan Frontier which states 6100 as the tow limit, but over 4500 requires WD hitch.
It's 2008 SR5 $WD. It did not state any new limits with the WD and I can guess why. It's effectively saying, going beyond 5,000 lbs maybe done "at your own risk" or now the responsibility of WD manufacturer who specified their own equipment capabilities.
May-21-2018 08:21 AM
May-20-2018 11:18 AM
May-20-2018 10:08 AM
May-20-2018 09:33 AM
daka320 wrote:
On my V6 2004 4Runner, I removed the factory hitch receiver mounted to the bumper. I replaced it with a "Hidden Hitch" received mounted to the frame. This increased the hitch weight to 600 lbs or so and increased the towing capabilities to 6300 lbs. I could also now use a weight distribution hitch to take the strain off of the overloaded rear axle.
May-20-2018 09:30 AM
May-19-2018 08:48 PM
May-19-2018 07:36 PM
