New RV-about to drive off the lot- Found Leak
rvbc
We are about to purchase a new Venture Sonic 22VBH today. I drove yesterday to the lot to look it over after a heavy rain and found a leak at the corner of the slideout.
Tech looked at it and said that hes fixed it with silicone sealant where a spot was missed. I will run a hose over the entire roof today to see if it leaks. This is my first trailer and I am nervous about the purchase. Is this normal? Should I ask to have them look inside slide out and take apart?
Thanks for any feedback!!
18 REPLIES 18
rvbc
ok, I will ask about the pressure test. The date of manufacture is March, 2017. It has probably been on the lot for 2-4 months, unsure how long the slide out has been open.
Also, while crawling on the roof to check for other seals I heard a couple cracks/crunching underneath - is that the fiberglass wrap? is it damaging it?
https://www.venture-rv.com/sonic-travel-trailers/construction.html
westend
Since you found a leak, see if they'll split the cost of a Sealtech pressure test. The interior pressure test will find any additional leaks or affirm that the original was repaired correctly.
'03 F-250 4x4 CC
WNYBob
Maybe a pressure test is in order!
darsben1
I would be leery.
The next question to get answered is how long has it been leaking.
See if you can find a build date.
Have the slides been out? If so the leak has done some damage.
Will it become evident before the warranty is over?
Traveling with my best friend, my wife in a 1990 Southwind
