Towing TT
JDolacki
I have a 29TE travel trailer, it's 6100 lbs empty, 7700 lbs loaded, my truck is a 2wd 5.3 V8 with the HD transmission cooling package, and towing package. It's a sylverado 1/2 ton 2010 crew cab, the dealership says I can tow up to 10500.
Will my truck be fine for this trailer, or will I be looking to get another pickup sooner in the near future.
I upgraded my WD to a Blue OX 1500 series, from the equalizer bar the RV dealership was going to sell me.
I'm not sure if I have the 4:10 gear ratio or the 3:73 gear ratio.
It does have the trailer option, on the shifter, to take it out of overdrive.
John
12 REPLIES 12
afidel
APT wrote:
All 2010 GM half ton crew cabs with 5.3L have 6-spd trans with 3.08 or 3.42 axle. Hopefully OP have the 3.42 as well as the HD trailering equipment. That gets tow rating around 9500 pounds. 10k+ is for the 6.2L and max trailering package. 6k dry is a good number and should tow well. Get a WDH with integrated sway control. The Trailer Tow button on the shifter does not eliminate OD, but does enhance towing experience as well as reduce transmission heat. Use it, plus I recommend M4, maybe M5.
Not sure about 2010 but my 2015 locks out cruise control when in m4/5 so I just use tow haul and cruise, we'll see in a few weeks if I can do that in the Rockies ๐Ÿ˜ƒ
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
lawrosa
coolmom42 wrote:
You appear to be well within your limits on cargo capacity and towing capacity, with less wiggle room on cargo capacity.
My advice is to try it for a season, in the type of travelling you normally do, and see how you like it.
Everyone has different ideas of acceptable towing. I don't feel a need to climb a mountain at 65 mph---that's what the right lane is for. If you are in it, you will not be alone. But if that's important to you, you are likely to need a bigger truck.
But we dont know what rear he has... The 3:08's have a low 6000 lb tow rating..
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
coolmom42
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
lawrosa
X2
Mike L ... N.J.
APT
2017 Subaru Outback 3.6R
Hannibal
We tow 8k~ with our 5.4L F250. I think your 5.3L GM has a bit more power if I remember correctly. I'm happy with the performance but most here probably wouldn't be as it downshifts to run 4200~rpm on the uphills. I have no plans to go to the Rockies with it.
Good luck with the hitch. I'd call it a downgrade from the Equalizer.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
WNYBob
I have a 2011 Silverado 1500 reg cab long bed, I also have the towing pkg, 5.3 v8 and 3.73 rearend. Tow of 9800.
I tow a TT that is about 4800 loaded! I'm comfortable with that, wife and I agree, that we don't want a bigger TT.
MFL
Nomad II
Nomad II
Since you already have the truck and trailer, you will soon know if you are happy with the current trucks capacity. Being a half ton, I think your gears would be 3.73. With the more powerful 2010 5.3, and 6-speed, your truck should work, although depending on passengers, gear, stuff in the truck, you may be near max payload.
Jerry
DinTulsa
You can more than likely tow that TT, but I don't think you will be happy with the results. That's a pretty heavy trailer for that truck, it will put you near the top of all your ratings. Your truck might be rated for 10,500 but I have my doubts. Try it out....I'm guessing after a few trips you will be looking to upgrade to a heavier truck with a stronger powertrain.
2Macs
I had the same situation when I purchased my first 26 Foot TT. At the time, I had a Chevy pickup and suburban, both with 5.3L w/ 4 speed and equivalent road ratio. It work OK on flat land, but on hills and mountains, I was pulled down to creeping speed some times. I traded the pickup in on a Chevy dually diesel with Allison transmission which I use on my current 37 ft. TT at 10,000 lbs loaded. It tows like the TT is not there on flat roads at 65 mph and has the power to go up inclines without dragging down.
Ed & Michele :C
Iraqvet05
Here is more info on finding your gear ration: RPO codes
From my own experience, pulling 5,000 lbs with a 5.3/ 4 speed and 3.42 gear ration Silverado was dismal. The truck did well on flat roads but struggled on small and moderate inclines.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
lawrosa
Go in your glove box and find the RPO code for your rear.. Post back and let us know. This will help us determine what you have.
RPO codes are as follows.. Click the link.
Example I have an RPO GU6 which is 3:42 rear.
http://www.crawlpedia.com/rpo_axle_codes.htm
Depends on the rear and your payload capacity.
Look on the door jam for a yellow sticker and let us know what the payload says on it.
look at your tires max psi on the side wall. Tell us what thats says and the max weight at that pressure..
Tell us what the code says. If you have the 6 speed you may have 3:08's. Which is common.
Im not sure it takes you out of overdrive. ( At least the 4 speed dont) It increases line pressure for firmer shifts. It increases the RPM's between shifts to hold you in the torque band. It locks the torque converter from second on up. It turns off alternater fuel save mod and cranks full voltage to trailer harness.
John
Mike L ... N.J.
