New trailer brakes
maroua
New trailer brakes. How hot and how much burning off of paint are consider normal?
2014 Dodge RAM 1500 Bighorn 5.7 Hemi, 3.92 axle
2014 KZ Spree LX 280 RLS
"Be content with what you have; rejoice in the way things are. When you realize there is nothing lacking, the whole world belongs to you." -
-- Lao Tzu
7 REPLIES 7
Bull_Rider
This is why I carry and use a Infrared thermometer. At every stop I shoot the hub temps, and I shoot the brake drum temps on each wheel of the RV. I will provide invaluable data regarding bearings and temps.
I even took off the decorative "cones" that cover the hubs to allow a better read on hub temps.
If you receive help from other members, don't forget to update your topic with the results.
maroua
Much better today. Thanks all
-- Lao Tzu
westend
maroua wrote:
I did, and that seemed to ease things. At first, it acted as if it was harder to pull, but when I down clicked the controller, it did not feel as if the trailer held me back when pulling at all. My best guess is that the controller was set too high initially?
Controller could have been set too high. The shoes and drums will have a certain run in time, too. I would suggest to check the hubs and bearings after a short break in time. I've read posts on here about loose bearings on new trailers. It's an easy thing to check if you can get under the rig with a jack and as long as you have a wheel up, adjusting the brakes is just another five minutes/wheel.
'03 F-250 4x4 CC
maroua
-- Lao Tzu
westend
Well, one good thing is that you know the shoes are making contact with the drum. If they get too hot, maybe back off on the controller.
'03 F-250 4x4 CC
maroua
Breakaway switch is intact.
Smell got better by the end of our short trip from dealership.
All cooled down overnight. Shirt trip to campground today. Will see if it reproduces.
-- Lao Tzu
mbopp
There should be no burning paint smell. You don't have the break-away plunger pulled, do you?
2019 F250 XLT Supercab
Just DW & me......
