No Electrical Outlet In Slideout
1L243
My new trailer has a slideout for the dinette/booth. This is my first trailer with a slideout. There are no outlets in the slide area. This makes it difficult to plug in computers and such. Is this typical for slides to not have outlets? I am going to try and come up with a way to put in a couple of outlets taking into consideration of the operation of the slide.
Any suggestions or pointers?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
17 REPLIES 17
chevyman2
You positive there are no outlets? look in front by the wall on each dinette booth. Does your have a couch (sofa) in the slide? If so check the wall behind that
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 2001 Jayco KIWI
If a "nightmare" is considered a dream-then I am living the dream
Community Alumni
Not applicable
Our's has outlets under the overhead cabinets in the slideouts.
Chuck_thehammer
my 2005 Coachmen has outlets at the slide-out dinette.
wire in using a power cord made like heavy duty extension cords..(14/3) be sure to allow for movement.. and nothing to pinch or cut cord in slides operation.
