No power from deep cycle battery
Bri13
This is the second battery I've tried without success, I've checked all fuses, shore power works fine. Any advice to troubleshoot getting the deep cycle battery to power our truck camper? We don't have a generator. We have a sun-lite cabover from 2003. We just bought this and are hoping to get her out on the road soon! Thanks!
4 REPLIES 4
Old-Biscuit
Battery POS cable.....trace it back to converter
In-line will be a FUSE.
Verify it is not BLOWN
IF FUSE tests good then locate the 'reverse polarity' fuse(s) (could be one or two...30A or larger) on converter. Test that those are not BLOWN
Chances are the In-Line Fuse on battery POS cable is problem
Course that is IF battery NEG is properly grounded.
KD4UPL
Do you have a main battery cut-off switch? Is it on or off?
ScottG
Any chance it got hooked up backwards? If so it will blow the reverse polarity fuses (3) possibly located on the converter away from the other fuses.
mike-s
You need a meter to trace voltages back from the battery. There's usually a thermal fuse between the battery and the "house." That may be bad.
Can't offer any more without specific detail.
