Jun-10-2021 11:49 AM
Oct-21-2021 01:39 PM
ticki2 wrote:
If folks read the title it a 2 way frig , no 12v option .
Oct-21-2021 01:06 PM
Oct-21-2021 11:43 AM
Geo*Boy wrote:riah wrote:
We ended up swapping back and forth during the summer from 12v to propane to keep the food cold and as importantly, to save on the use of propane a bit.
(Plus propane has increased substantially here in the northeast so definitely want to use the 12v from the dc dc charger and solar as much as we can! Also, we don’t like running on propane as it’s not safe, legal or recommended.:hReality Check wrote:mbloof wrote:
For me personally, I'll 'precool' the fridge by having the camper plugged into shore power and using the AC option 1-2 days before leaving on a trip.
Then I'll transfer precooled items from my house fridge/freezer to the campers fridge/freezer. I'll usually SHUT OFF the campers fridge/freezer before pulling out of my driveway.
While I live in Oregon and travel mostly in Oregon/Washington and the temperatures generally don't get higher than the 90's, I've found that the campers fridge/freezer will keep my items just fine (no matter what time of the year it is) during the 1-4 hours it takes to reach where I'm going.
When I reach my destination and start setting up, the campers fridge/freezer will get turned back on set to AC (if available) and propane if AC is not available. I see/find no need for the 'DC' mode/setting at all.
Obviously YMMV,
- Mark0.
Why do you turn it off when traveling?
Oct-21-2021 11:15 AM
Obviously YMMV,
- Mark0.
Oct-21-2021 06:06 AM
Obviously YMMV,
- Mark0.
Oct-20-2021 10:04 PM
(Plus propane has increased substantially here in the northeast so definitely want to use the 12v from the dc dc charger and solar as much as we can! Also, we don’t like running on propane as it’s not safe, legal or recommended.Reality Check wrote:
Oct-20-2021 09:50 PM
MT BOB wrote:
As NRALIFR has said.
The 12v in 3-ways was designed to be used only when driving, and to "maintain" temps. And, over the years, many were poorly installed, and killed many batteries.They should be hooked up so the element only works when the vehicle is running, and now, they use modules that shut it off if voltage gets too low, usually about 13 volts. I added 12v to mine, RM2501, because I like to experiment,and I used one of the relay modules that they use in the UK and Australia, set the voltage to turn off the element at 12v. It can keep the fridge at 35f, but I have only used it 2 times, I expect it will not when it is 90-100f out. I have a small inverter, in case I have to take a long driving trip,and will use it on 120, especially in hotter weather,while driving.
Oct-20-2021 09:41 PM
Obviously YMMV,
- Mark0.
Oct-20-2021 08:58 PM
Obviously YMMV,
- Mark0.
Oct-20-2021 08:49 PM
NRALIFR wrote:
If all the inverter is going to power is the fridge in AC mode, then yes, a 3000 watt pure sine inverter is overkill.
You need to check your specific model fridge, but the AC heat element in mine is less than 350 watts. You don’t even need a pure sine inverter for it either. I ran mine for several years using a 500 watt modified sine inverter and it worked just fine. What I didn’t like about that inverter though was the cooling fan on it was a screamer. It didn’t matter that much though since it was only on when we weren’t in the camper to hear it. Once I had other uses for an inverter though, I bought a better, quieter, PSW model.
Oct-20-2021 01:47 PM
Obviously YMMV,
- Mark0.
Oct-20-2021 11:20 AM
Oct-20-2021 10:52 AM
Oct-20-2021 09:45 AM
