โNov-30-2018 05:10 AM
โNov-30-2018 07:17 AM
Sliding-into-home wrote:
Thanks! yeah, all this ended up being over my budget as well, but it looks like they hold their value quite well. If money gets tight, she'll have to be downgraded, but I've been very frugal for a very long time, and if I don't enjoy some of what I've saved by making memories with my son/wife, all that will be left of me is an inheritance and life insurance policy.
โNov-30-2018 07:03 AM
With respect to the stable loads, they are definitely in contact with the spring, even before I have loaded the camper with gear/water. The lower overload gap is essentially gone as well.
โNov-30-2018 07:02 AM
sbryan@vtbryans.com wrote:Sliding-into-home wrote:
Makes sense. I'm guessing if I started with the laundry list, I wouldn't have any (potential) issues. My new Nokian LT2s get here today hopefully. Soon, in any event! (3640lb rating).
The better tires will help. I've had great luck with the Rotiivas in the snow but the LT1's will be even better. Nokia make great tires.
Nice looking rig. Just checked out your profile pic. We liked the Northern Lite a lot but it would have put us over our "budget". The Northstar has been a great winter camper - yours should be as well.
โNov-30-2018 06:57 AM
โNov-30-2018 06:52 AM
โNov-30-2018 06:49 AM
I don't have issues with everything I did. I didn't do a progressive install. After a lot of research I decided what I needed to do to make the truck roadworthy with the camper and did it all at once (except for the sway bar and Bilsteins, which I did as soon as I got the truck because the OEM shocks and lack of sway bar were already on my have to fix it list). Everything else was done the day I bought the Igloo. After over a year, trips to Alaska, Florida, Alabama, Canada, etc I can truthfully I wouldn't change a thing.
Do air up your tires to 80 rear and al least 65 front - I run 70 front. And I am a big fan of better tires than the OEM. My truck came with Michelins and the difference between the Michelins and the Nokians is night and day - higher weight rating, stiffer sidewalls and much better tread.
Good luck.
โNov-30-2018 06:47 AM
โNov-30-2018 06:46 AM
Bedlam wrote:
Adjust the FastGun turnbuckle so when you look through pin/lock hole tension starts once half of the hole is obscured, the remaining closing action should be under tension.
โNov-30-2018 06:41 AM
Are you sure the fastguns if you have them are adjusted right?
Only thing I know about adjusting fastguns is what the tech at the dealer told me during delivery. Tight enough to just barely require 2 hands to close, and always on the hook that's farthest away. Closing the front ones, I can visually see the cabover drop about a an eighth of an inch as it cinches down on the bed mat. That sound right?
โNov-30-2018 06:34 AM
Also, since I'm almost certainly going to do the Ranchos, which model number do I want? I see multiple options that will fit my truck.
โNov-30-2018 06:31 AM
โNov-30-2018 06:30 AM
โNov-30-2018 05:52 AM
