one more hot water tank question
kramer45011
My hot water tank stopped working after running out of propane and once replaced still wouldn't work. I have tried suggestion on here with no luck. When you flip the switch (DSI) it doesn't even try to light.
My question is can i manually light the pilot and if so how do i go about that?
10 REPLIES 10
joelc
Do you also have electric back up? If you do there are 2 reset switches on a Suburban. Rubber black buttons, I assume on just propane there is one. Try pushing that switch to reset. You either have no 12V, no propane flow or a bad reset switch. Hopefully, it is not the PC board.
newman_fulltime
Ron3rd wrote:
Who replaced it?
He was talking about replacing the propane
Ron3rd
Who replaced it?
Equilizer Hitch
Honda EU2000
newman_fulltime
Because it went into lockout mode.unplug the plug from the black box for a minute then plug it back in and turned the switch on
12th_Man_Fan
You said it doesn't even try to light. If you don't hear the snapping when the lighter sparks then you probably can't light it manually. If you don't hear the sparking then you probably don't a 12 volt supply and the gas valve will not open without it.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
RoyB
We always make sure the propane is working by using the stove top. This also will remove any air that might be resent in the feed... Some propane tanks have a safety feature that if you turn it on too fast it will shut down... This is another good reason to always try your stove top first to be sure the propane is flowing ok and burning with a BLUE flame...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Lwiddis
OP needs to learn about his rig....reading, not asking.
richardcoxid
Also DSI means โ€œDirect Spark Ignitionโ€ it does NOT have a pilot! The burner is lit by a electric spark controlled by a circuit board.
Do you have 12VDC available, do you have a blown fuse? Or bad circuit board?
2017 GMC Denali 3500 4x4 Duramax
2019 Outdoor RV (ORV) Timber Ridge 24RKS
Lynnmor
Post the make and model. Look in your owners manual also.
Lwiddis
Does it have a pilot light? You provided no maker, model, year etc. Didnโ€™t you ask this on June 8th?
