Mar-19-2014 05:05 PM
Mar-25-2014 09:56 AM
okan-star wrote:
...Had to order the new Rieco Titan EZ Swings...
Mar-25-2014 09:54 AM
Mar-24-2014 04:15 PM
PRodacy wrote:
Make sure you know the difference between an open diff, a limited slip, and a locker. Open diff = one wheel slips, all the power goes to it and the vehicle won't move. Limited slip = one wheel slips, power goes to the non-slipping wheel and you get moving again. Locker = both wheels are virtually locked together. Lockers are almost never used on the street, regardless of the conditions. They're common on off-road vehicles where you want to keep moving in very rough terrain or even if one or more wheels are off the ground. On ice or very slippery conditions, lockers are often a more squirrely if the road slopes to the side since both wheels are turning at the same speed. A LSD is better in these conditions as the one wheel that isn't driving tends to hold the vehicle a bit better. I'd definitely go with a LSD, not open and not locked unless you're really into off-roading in severe terrain.
Mar-24-2014 01:32 PM
Mar-24-2014 12:11 PM
Mar-24-2014 11:51 AM
Mar-23-2014 07:32 PM
Mar-23-2014 03:28 PM
Mar-23-2014 02:23 PM
Rexsname wrote:
Jefe,
What is your opinion of the Tru-Trac LSD? It is an all gear (no clutches) LSD. REX
Mar-21-2014 09:21 PM
jefe 4x4 wrote:
okan,
Good job on the find. Make sure to count the splines once they open up the pig in Sacto.
With only 16K miles, the Trac lok should be O.K. Just keep the oil and additive up to date.
The AAM look-similar rr diff to the D80 has only a 30 spline outer, not something to write home about.
jefe
Mar-21-2014 08:16 PM
Mar-21-2014 07:28 PM
Mar-21-2014 05:55 PM
Mar-21-2014 04:26 PM
