โJul-07-2017 08:43 AM
โJul-10-2017 12:55 PM
โJul-09-2017 09:17 AM
โJul-09-2017 09:02 AM
โJul-09-2017 08:35 AM
โJul-09-2017 04:52 AM
โJul-08-2017 11:27 PM
Freep wrote:
The constant enemy of campers is water and the resulting wood rot. I've read here of people having water damage to their campers even when it is only a few years old. Even though many manufacturers use aluminum framing now, a great deal of the internal construction is still wood, leaving you with a potential of severe structural compromise when water gets in.
Has anyone done a rebuild using composite material? It seems to me that this would be a great way to have some peace of mind to protect against rot. I'd be happy to pay a manufacturer a little more to use composite rather than wood.
What do you think? Am I crazy?
โJul-08-2017 11:21 PM
Reddog1 wrote:HMS Beagle wrote:I would raise (pedestal) the area of the penetrations 1 to 2 inches. The pedestals would be molded in. The flanges of the penetrations would be about 2 inches wider than the item fitted to the penetrations. For example, the standard opening for vents and A/Cs is 14 inches. I would make a pedestal 18" by 1 or 2 inches high. With the raised pedestal, it is very unlikely you would have a leak at that point.
... Then be very careful about the roof penetrations - how many and how treated.
Wayne
โJul-08-2017 11:18 PM
โJul-08-2017 09:56 PM
โJul-08-2017 09:34 PM
โJul-08-2017 08:12 PM
Kayteg1 wrote:
You think aluminium chanel would rot?
The only problem with them is when owner let the skylight deteriorate or don't wipe the floor after taking shower.
Floor is still plywood.
โJul-08-2017 08:05 PM
Kayteg1 wrote:Freep wrote:
Um... dry rot would be under the skin, would it not?
โJul-08-2017 05:14 PM
โJul-08-2017 05:12 PM
