Power jack makes "clank" sound and doesn't work
chracatoa
So when I was ready to leave the campground today the power jack was doing a "clank" sound for every turn and it basically didn't move.
I did it manually but it still made the clank sound for every turn.
After it was off the trailer it moved up and down freely but still making the same noise.
It is under warranty (or it should be). I don't want to drive to the dealer though (1 hour away).
Any ideas what is happening and should I ask for a new one?
2011 Toyota Sequoia Platinum 4WD 5.7L V8 (next one will be a 3/4, someday)
2012 Jayco Flight Swift 267BHS (5963lbs dry, 6850 wet)
Propride hitch (I had a Reese dual cam round bar WDH for 4 months)
6 REPLIES 6
chracatoa
I'll take a look at it this weekend. It turns out the warranty on the jack was expired. If everything else fails I'll just add a new jack.
thib2722
I would take the darn thing apart before spending 170 on a new one. It might be a 50 cent part. Shear pins are designed to break before the jack does. You could find a replacement at any good hardware store.
My neighbor gave me a mower because he said it was broken and wouldn't run. He tried to mow a tree root. I replaced a 25 cent shear pin and it ran like new.
chracatoa
Well, I called Jayco and they don't want me to touch the Jack inside. The problem is that I'm far away from the dealer. And the closest dealer has a wait of two weeks. And I'm leaving on a big trip next week so I don't want to try to fix it and fail.
So I'm thinking in buying one and installing it myself. I can have the other one serviced by the end of the year when we're not camping anymore.
Also I can't find a manual jack that can take 3500 lbs. I wonder if there is one?
I found oneelectric for 100 dollars but not sure if it's good - reviews say it's slow.
There is also an Ultra-Fab Products 38-944016 for around 170 dollars.
Any suggestions?
phemens
Concur on the shear pin. When you call them and ask for a replacement, have them send you two. Keep the spare in your toolbox for the next time!
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
dalenoel
Sound like the problem I had with an UltraFab shear pin. I called the factory and they sent a new one under warranty.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
hammer21661
Probably stripped gear or shear pin.
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
