Power Slide Out Motor
JThybrid
I need to replace the Power Slide Out Motor on my 2011 Shamrock 233s (similar to Roo 233s). The motor p/n VT00310R, model# IA06501222-00, 12vdc, 30 amp, 17 rpm, 360:1 ratio. Cannot find anything with above part#, looking for replacement part number for a new motor that will work with my slide out. Thank you in advance.
5 REPLIES 5
subcamper
The slide motor wouldn't turn on my 2004 Rockwood even though there was power at the motor. It turns out the brake was defective. In my case, the brake was attached to the end of the motor opposite the end with the gearbox. The brake grabs the shaft when there is no voltage to the motor. When the motor gets voltage to turn, the brake also gets 12V so it can disengage. It was not disengaging, so the motor couldn't turn. I removed the brake assembly off the motor and the slide worked fine. The brake assembly had its own manufacturer and model number, so I called the manufacturer of the brake and they sent me another one.
I don't know if your setup is the same (I have a rack-and pinion drive for the slideout), but you might want to check the brake if you have one.
Steve
trimoutinc
Was you ever able to find a replacement motor for your slide out. I have the same model number and part number in trying to replace
SAND-WINTER
WATER-SUMMER
Bears_Den
You might also check for a loose connection from the battery to the selonoid which is usually found on the A frame of your trailer. I have had that problem before, wire was loose and not making a good connection as a result the slide wouldn't work. Tightened it up and all was good.
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
Bionic_Man
Your trailer is a 2011, and already needs a new motor?
Have you checked the fuse for the motor? I had that problem last fall. Mine is away from the motor, up in a front storage compartment.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Edd505
Try here https://www.factoryrvsurplus.com/categories.php?category_id=169
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
