Sep-03-2020 03:55 PM
CB
Channel 17Redneck Express
Sep-04-2020 05:14 PM
Sep-04-2020 11:51 AM
DWeikert wrote:DWeikert wrote:
I use a Xantrex ProWatt 600 and added their remote panel to turn it on or off from the bed.
PS: Xantrex also makes a nice transfer switch which I also use. Not that this couldn't be used with any inverter...
CB
Sep-04-2020 11:45 AM
JimK-NY wrote:
Joe, sorry if I sounded critical. I merely want to suggest looking at using an inverter as little as possible and getting the smallest inverter that will work. As I am sure you know, inverters can waste a lot of battery power but it seems that is not an issue for you.
CB
Sep-04-2020 07:52 AM
Sep-04-2020 07:46 AM
theoldwizard1 wrote:Kayteg1 wrote:
Funny part, inverter come with factory cables about 2 ft long. They are #8 wire.
I have noticed that also ! You would be better off getting rid of those cables and getting some larger cables. If you think you would ever be close to pulling 4000W that would be be over 300A ! Even a more realistic 3000W would be well over 200A !! For that load, I would want at least a #2 wire .
Sep-04-2020 07:43 AM
Sep-04-2020 07:41 AM
Kayteg1 wrote:
I am also observing inverter/chargers as those would simplify converter and transfer switch setup, but those still keep high prices.
Sep-04-2020 06:42 AM
Sep-04-2020 05:07 AM
Sep-04-2020 04:22 AM
Sep-03-2020 09:57 PM
JimK-NY wrote:JoeChiOhki wrote:JimK-NY wrote:
What are you planning on running with this pure sine wave inverter?
Mostly the same stuff we were running off the Modified, small electronics (TV, roku, laptops, low load stuff) and the 2-way fridge while driving (We have a whole change over circuit that switches a block of outlets between the short power outlet and the inverter circuit.
I fail to see the need. My TV runs on 12volts. I have laptop and cellphone chargers that are 12 volt. My wife's CPAP runs on 12 volt. The refrigerator is 12 volts. About all that remains are camera and flashgun battery chargers and I have a small, cheapie, non-sine wave inverter for charging them.
CB
Sep-03-2020 09:39 PM
CB
Sep-03-2020 08:33 PM
Sep-03-2020 08:20 PM
