Aug-26-2019 06:53 AM
Aug-28-2019 04:18 PM
Aug-28-2019 12:08 PM
Aug-27-2019 08:23 PM
Npdchief07 wrote:
So when not in use I should have the battery disconnect turned to off?
What does the battery power?Some things may seem obvious. Lights, electric tongue and stabilizing jacks if so equipped, slide motor(s), awning motor, etc are all "obviously" battery powered. I expect what you really meant was I'm not using these obvious things while its sitting in the driveway, assuming you didn't leave a light on by accident. So why is the battery dead? There are some not so obvious things, especially if you're new to RVing. Every RV is required to have a gas detector installed and this runs anytime the battery is connected. Some have battery powered CO detectors and/or smoke detectors. Traditional RV refrigerators will draw power from the battery if they are set to gas or DC. Newer residential refrigerators have power inverters that convert battery power to AC to run the refrigerator. These will drain multiple fully charged batteries in a matter of hours if left on. Some RVs have smaller inverters for powering a TV or other appliance but these aren't usually installed from the factory. The furnace may draw power if the thermostat is set to furnace. Even if it doesn't need to run, the control board my use power. The thermostat itself on most newer RVs is powered by the battery. Some have clocks powered by the battery.
Aug-27-2019 07:57 PM
2oldman wrote:Npdchief07 wrote:They should call it a battery connect. That way it makes more sense to be "off."
Aug-27-2019 04:39 PM
troubledwaters wrote:Even the emergency battery powered brake system? That is the most important thing to have powered and should always be powered even with a disconnect switch interrupting any power to the trailer. It will draw no current when in the standard, non operating, position so isn't a drain on the battery(s). If the emergency brake switch on the trailer tongue is not powered, add a wire, a fuse, and the correct terminals from the switch to the battery, bypassing the disconnect switch.camperdave wrote:That is not always true. When I turn my disconnect switch off, everything is off; there are zero loads connected.
Even with the disconnect switch on the off position, you will still have a small load...
Aug-27-2019 06:27 AM
Aug-27-2019 02:46 AM
Aug-26-2019 08:25 PM
Aug-26-2019 09:14 AM
Aug-26-2019 09:05 AM
Aug-26-2019 08:36 AM
Aug-26-2019 08:22 AM
Npdchief07 wrote:Yes. Unless you plug in then it may as well be on to get the charge topped up.
Aug-26-2019 07:56 AM
Aug-26-2019 07:46 AM
Npdchief07 wrote:Everything 12v: lights, jacks, slides, refer control board, furnace control.
What exactly does that battery power?
I don't understand electrical. I don't know a volt from an amp.
