โAug-22-2014 10:38 AM
โAug-22-2014 11:08 AM
โAug-22-2014 10:59 AM
โAug-22-2014 10:56 AM
AH64ID wrote:
As stated the grease goes to the inner bearing, and then the outer bearing thru heat and hub design.
Ez lube axles make it too easy to over grease the bearings, which can be as bad as under greased.
Many recommend ignoring the zerk fitting and just doing proper packing annually. Even my axle manual states that the ez lube fitting does nothing to extend the standard packing service interval.
โAug-22-2014 10:50 AM
โAug-22-2014 10:47 AM
coolbreeze01 wrote:
EZ Lubes are different than bearing buddies.
The grease flows to the rear bearing first.
I'm sure someone will post a diagram for you.
โAug-22-2014 10:45 AM
