โSep-28-2013 12:06 PM
โSep-28-2013 07:16 PM
69 Avion wrote:
I have ordered a 250 watt Sharp 24 volt Solar panel. Now for my question. I would like to use a Morningstar Sun Saver 15 MPPT controller. The problem is that the sales person said that the 15 amp MPPT Sun Saver controller isn't large enough for my panel. Does anyone have experience with this? I don't want to have to go to a 45 amp controller unless I absolutely have to.
โSep-28-2013 05:26 PM
โSep-28-2013 05:11 PM
westend wrote:
The Morningstar MS-MPPT-15 will clamp output at 15 A. If you exceed the input up to 70 V, IIRC, the maximum output will still be 15 A. With two 24V nominal panels in series you may be exceeding the high voltage rating, depends on panel voltage maximum and if you connect them in parallel or series.
I use this controller with a single 235W panel. It performs excellently. The RS232 interface is a seamless way to adjust charge voltages and observe charging characteristics. When I plotted my system, I took into consideration adding another panel. I decided I could, at that future point, add another controller if needed. As it has turned out, the single panel meets my charging needs. One surprise to me is that these polycrystalline modules will still be harvesting power on the shoulder hours of the day. Mine harvests even at sundown, albeit at very low amperage output. It is "the little controller that could".
โSep-28-2013 04:56 PM
โSep-28-2013 04:24 PM
JiminDenver wrote:
Do you go up in altitude? My 230w panel sees a increase of over 50% at altitude, you may be loosing more than you think.
I've had good results using the Eco-worthy 20a MPPT controller with a single panel. I was hoping one of the really low cost ones would at least functions but no luck so I'll be getting a second Eco-worthy for the inverter bank.
โSep-28-2013 04:21 PM
โSep-28-2013 03:34 PM
69 Avion wrote:
Lets hear from the folks that have the Morningstar Tri Star 45 amp MPPT controller.
โSep-28-2013 03:28 PM
69 Avion wrote:34 x 13= 442w. It will power any size inverter, but it will not support more than 442w draw from that inverter.
With two of these panels working at optimum level, what size 110 volt inverter could it power through the batteries with minimal loss from the batteries during the optimum level?
โSep-28-2013 02:54 PM
โSep-28-2013 02:47 PM
โSep-28-2013 02:36 PM
โSep-28-2013 02:09 PM
harold1946 wrote:It would have to increase the amps, right? If it doesn't, better get a better controller.
The MPPT controller receives the 24 volt input from the panel and adjusts it to 12 volt without reducing the amps.
โSep-28-2013 02:03 PM
2oldman wrote:CA Traveler wrote:I think I'm confused in that he's charging at 12v, not 24, so the 15a still holds.
MPPT controllers take the input voltage and current and convert it to the output voltage and current. He can possibly get 17A output
โSep-28-2013 01:53 PM
โSep-28-2013 01:39 PM
