โSep-28-2013 12:06 PM
โOct-02-2013 06:48 PM
โOct-02-2013 06:17 PM
โOct-02-2013 04:43 PM
69 Avion wrote:I'd be careful with that. Perhaps there's a wind load spec on the panel itself.. not the frame, the cells themselves.
I can use it to deflect the wind.
โOct-02-2013 04:41 PM
โOct-02-2013 04:09 PM
69 Avion wrote:
The term "run" was actually a question of how much does it cost? I should have been more specific. I use too much slang.
โOct-02-2013 04:05 PM
69 Avion wrote:No. None.
Do you put automatic circuit breakers in the line (+) from the solar panel and also from the controller to the battery? Also, what kind of switches, or disconnects do you put between the devices?
69 Avion wrote:Ok, this sounds weird. Why? The first pebble that hits it at 60mph will damage it.
After looking at the panels, I need more aluminum before I can mount the first one. I'm mounting it above the tongue and I will be using it for aerodynamic wind flow so the angle will be adjustable to direct the wind while traveling.
โOct-02-2013 04:02 PM
โOct-02-2013 02:19 PM
โOct-02-2013 12:26 PM
69 Avion wrote:Well, those manual breakers are expensive compared to a good 25-50 amp fuse. Also the fuse is probably faster acting then the circuit breaker. In common use, there really isn't a need to interrupt between the charge controller and battery, especially if the module output to the controller can be switched.westend wrote:69 Avion wrote:
Westend, thanks for the link.
You're welcome.
Forgot to mention, you'll want a fuse between the charge controller and battery, protection for that wire.
What do you think about putting the manual circuit breakers on both sides or the controller?
โOct-02-2013 11:28 AM
You're welcome.
โOct-02-2013 07:42 AM
โOct-02-2013 07:06 AM
โOct-01-2013 09:03 PM
โOct-01-2013 08:15 PM
โSep-29-2013 05:23 PM
JiminDenver wrote:
At least there are a few more functioning smaller MPPT controllers now. The Eco-worthy didn't come out for a year after I found my panels and everything else that was affordable was fake junk. After paying $50 a panel it was hard to swallow hundreds to stay charged up for a week or two at a time.
Even though 230w has been more than enough for us, I would get the second panel in a heartbeat. You will want a matched set if you ever mount both and combine them. I'm stuck with separate systems if I use both panels.
As far as bumping the limit, unless you are really draining a big bank or doing big power draws at noon, you may not have to worry about it. Even with our panel flat we were in float pretty early and never saw full power at noon unless I was trying to use power.
the two things I'd change on the Eco-worthy are to have the ability to turn off the MPPT when it's cloudy and be able to set a time duration on the absorb stage. It doesn't last long with shallow discharges and while I can hold the float up to 14.5v if I want, it's not automatic. Other than that I can't find any bad reviews after a year .
