Question for Ram Owners who use the torklift extension
cartmancartman
For the late model Ram owners who have installed the Torklift hitch, does your setup have 2 receivers from Torklift or did they sell the one receiver setup and you have to use the original factory hitch? I was told on the Ram body you cant remove the original hitch as it would void the warranty per Torklift, the dealer says opposite. There is too much flex in the factory hitch for my intended use.
d1104/d1108
6 REPLIES 6
cartmancartman
I am considering adding the 20k hitch to my truck, torklift says the current rear tie downs(D3109) wont work with the upgraded hitch. I really dont want to spend $$$ for upgraded tie downs (R3507) , has anyone modded theirs to fit?
computermonkey
My truck is the 2013 RAM 3500, it has the 30k Magnum installed. I'm using the 42 inch 12000 rated extension dual tube.
New
2013 RAM Crew Cab, 3500 4x4
2019 Arctic Fox 1140 wet bath
Old
2016 Eagle Cap 960
2004 Jayco Talon ZX
1998 GMC Suburban with a Cummins 6BT conversion.
Troutguy
egarant wrote:
Yes it works just fine. I also have the 20K Super Hitch and the upper tube slides into the factory 2.5" receiver and the lower 2" Torklift receiver.
I found that the Torklift 2 1/2” to 2” adapter, that they provide, is totally useless and the OEM adapter that comes with your RAM works much better. The TL adapter is too short and too tight and makes inserting the SuperTruss extension extremely difficult......the RAM adapter makes the extension go in like butter. Torklift I hope you’re reading this!
2018
RAM 3500 Crew Cab 4x4 DRW
Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWR
2018 Arctic Fox 1140 Truck Camper &
Honda EU2000
egarant
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
cartmancartman
thanks!
Troutguy
I have a 2018 RAM Dually and recently installed the Torklift 20k Superhitch and it does use the factory hitch as the top tube. It piggybacks both the Torklift and RAM hitch and they are bolted together to form a single twin-tube unit. I believe that I used the D1108 because the frame on the 2018 is different than the 2017 and earlier trucks. The Torklift also bolts on to the RAM’s side plates underneath. As usual the Torklift instructions are not very clear but you can figure it out as I installed it myself.
TG
2018
Honda EU2000
