Apr-10-2018 06:22 PM
Apr-11-2018 05:52 PM
LVJJJ wrote:
The best thing about the Trail Lites-Cruisers is the aerodynamics, they cut thru the wind and as the undersides are enclosed or smooth, there is little turbulence. The TC is heavier than the Tahoe Lite we got rid of, but its easier to tow cause the design is slipperier
SoundGuy wrote:
Sorry to disappoint but that's an Old Wives' Tale - TrailCruisers, Trailites, tow no differently than any full height trailer, nor does the enclosed underbelly make any difference at all other than in advertising. If anything helps at all it's that RVision products were generally lighter than anything of similar sizes at the time. I got the same average fuel mileage returns towing our TrailCruiser C21RBH with our 2006 Silverado as I do now towing our similar size but much heavier Coachmen Freedom Express 192RBS (with an open underbelly) with our current 2012 Silverado. 😉
d2tw4all wrote:
Playing devils advocate though, you tow with a pickup and we are using SUV’s, which absolutely have significant differences in how they both tow and the aerodynamics involved.
d2tw4all wrote:
I definitely could see the SUV streaming air differently over the trailer.
Apr-11-2018 04:03 PM
Apr-11-2018 04:00 PM
LVJJJ wrote:
Recently bought a 2005 Trail Cruiser 26CBQ, supposed to be around 3,000 dry, its the kind with the laminated panels with insulation in between. Weighed it with probably 3/4 of our junk in it and it was 4800 lbs. We don't have 1800 lbs in it. In 2000, we had a 30' long Trail Lite and it was light, couldn't feel it behind our 454 Suburban. The best thing about the Trail Lites-Cruisers is the aerodynamics, they cut thru the wind and as the undersides are enclosed or smooth, there is little turbulence. The TC is heavier than the Tahoe Lite we got rid of, but its easier to tow cause the design is slipperier
Apr-11-2018 03:52 PM
Apr-11-2018 03:32 PM
Apr-11-2018 09:27 AM
SoundGuy wrote:d2tw4all wrote:
I went this morning and did a close inspection of the trailer and it looks to be in excellent condition, so I'm going to move forward with the buy.
Just keep in mind this is an orphan trailer and although some will tell you that's not a big deal there will be parts you simply won't be able to get, should that ever be necessary.
Apr-11-2018 07:27 AM
Apr-11-2018 06:50 AM
Apr-11-2018 06:39 AM
Apr-11-2018 05:15 AM
Apr-11-2018 03:06 AM
d2tw4all wrote:
Appreciate any info on this, as if accurate I'll be snapping this baby up tomorrow. I just want to know if it's not accurate, what the real weight is...
Apr-10-2018 08:54 PM
Apr-10-2018 06:43 PM
