Ram slide question.
jonmad
Should rams on super slide be equally spaced? Mine has the rear slide about 1 foot from the rear and the other is about 4 feet from the front. Seams to work okay but comes in slightly angled. If anyone has a similar setup could you tell me if there have been any problems with it?
5 REPLIES 5
eHoefler
There is a timing shaft that is geared to each ram to keep it moveing straight
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Old-Biscuit
Rams are placed:
Where there is room to locate them
As needed for weight carrying provided there is room
Where they can be located
Overthinking it........
Not going to be moved/relocated as they are where they are based on above :B
jonmad
Thanks to all. Guess I'm an over thinker.
MFL
Nomad II
Nomad II
Even with the same mechanisms, each trailers slides have their own compromises. Each and every adjustment may not be exact, but trying to make one exact, may just make another not align as well. If it works good, I'd not mess with it, or have a very competent tech take a look at it, to get his opinion.
You don't see a lot of response to slide adjust questions, due to one persons fix not being a fix for all.
Jerry
Passin_Thru
Shouldn't make any difference where they are placed as long as they push evenly.
In a perfect world, Everything wouldn't be.Yogi Berra
