Rear inside tire wear. Bent axel?
Frznrth
Hi
I have a 4 year old 30' bullet. I noticed that the inside of both rear tires are completely worn out - a bit on the outsides too but not nearly as bad. The fronts are wearing fine fand only maybe 1/3 gone. I read this can be from a bent axel. I do see a wow in the axle but have also been told that some bend is normal. True?? I don't remember doing anything that would have bent an axle. Replace the axle?
Am I good to replace the tears with new ones or do the fronts need to match?
Thanks for the time.
15 REPLIES 15
Still_Searchin_
Just running up and over a 4" curb in a parking lot can bend an axle. I had inside wear on my dual axle Jayco, and even though I had not exceeded my GAWR, one of the posts here recomended getting heavier 5000# axles rather than keeping the original 3500# axles, which I did, and sure enough, inside wear went away. Checking alignment is also a good idea.
2011 Jayco Eagle Lite 256rks 28ft. travel trailer; Reese SC hitch
2010 Chevy Silverado 2500 6L w/3.73 differential
Member: TTN, Escapees, Good Sam
3x around USA, traveling about 6 mo/year
