Reinforcing toilet/shower/black tank combo
logcruiser
Hello,
This is my 1st camper and I have learned a lot from this forum so far... thanks!
I have a black tank drip from either the threaded pipe going into the tank or possibly the flange on the tank. I pulled the toilet first (need to change the seal) and I noticed that the tank was bolted to the top of the tank with no flange. This method of mounting allows the toilet and tank to flex a lot. I am worried about this cracking the tank. Is there a way to add strength to tank?
Thanks,
Mike
7 REPLIES 7
Home_Skillet
Ok. I see what you have.
That would be a tough one to strengthen.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
logcruiser
If I right click on the word image it gives me the choice to view image.
Home_Skillet
This?
Home_Skillet
Photo is not coming through.
logcruiser
It looks like this
logcruiser
The toilet mounts to the top of the tank near the front and the drain pipe in at the bottom rear of the tank. I don't think that would work.
Thanks,
Home_Skillet
You can extend the pipe that is going into the black tank.
Mount a piece of 3/4" plywood (with a hole for the pipe) to the floor and screw the toilet flange down.
